Fuel Pump Alternatives?
Old May 18, 2010 | 06:20 AM
ron's power stroke's Avatar
ron's power stroke
im doing a fuel mod right now..im shooting for 500 + HP this winter..so i been doing a lot of searching, reading and asking to end up with my sump and fuel lab...i only want to do this once.....most will tell you rather then a walbro..go dual SD pumps...its a little cheaper then going with the fuel lab or fass pumps..and if one quits the other can still get you home if the mod is done right..
Old May 18, 2010 | 06:28 AM
Visseroth's Avatar
Visseroth
Not finding any negative information regarding the pump and I wouldn't mind running the stock pump if I could sustain the stock PSI at WOT, it didn't cost a arm and a leg and wasn't limited to 450hp. I may or may not run more then 450hp later down the road but seriously! these trucks are SD's! They should have a SD pump that is more then capable for these trucks for every application including high performance.
Anyhow, I just want to be able to maintain a steady fuel flow to both the injectors and to the return and not get ripped off for a stinking pump.
Old May 18, 2010 | 06:33 AM
Visseroth's Avatar
Visseroth
educate me then, how are you going to do this setup?
ron's power stroke
Originally Posted by Visseroth
Well that doesn't make any sense considering gas is much thinner and less of a lubercant.
So what would you recommend. Another guy recommended the e2236.
ever see what happends to a gas line rated for gas that has been used on diesel ???
Old May 18, 2010 | 06:37 AM
ChunderDownUnder's Avatar
ChunderDownUnder
Gotta say Ron, everything I have read so far confirms it a good pump. Will flow more than enough for most injectors and is well priced. Searched "fuel pumps" and "walbro fuel pump". I dont deny that some have had failures but like I said for the price it rocks.
Old May 18, 2010 | 06:38 AM
ron's power stroke
5/8 line from my sump though the 1212 filter though my fuel lab and into my 2 micron down on the frame rail..then 1/2 line going to my ITP fuel delete with DI's RR..from there the return line will be done with 3/8.... my pump can flow 150 GPH at 70 PSI on high speed....60 gph at 40 PSI on low speed without any drop in PSI what so ever... the sump lets fuel flow to the pump by gravity there for the pump will only be pushing fuel..the pump wont work at all trying to suck fuel up and out of the tank there for longer life for the pump and no chance for air...also saves on the cost of a lift pump...
Old May 18, 2010 | 06:40 AM
ron's power stroke
off to work..when i get home ill pm you some links..
Old May 18, 2010 | 06:42 AM
big_stroker's Avatar
big_stroker
Been running a Walbro with over 500+hp for over a year now with no issues. Hold 60psi fine.
Old May 18, 2010 | 06:45 AM
kirkharrod's Avatar
kirkharrod
I have been using this Bosch pump to pump diesel AND waste vegetable oil for 35,000 miles (and who knows how long it pumped diesel before I bought the truck!) If this pump will pump WVO, it's pretty tough! Especially for $99!
Bosch F81 U-9350-AA 0580464074 Ford Diesel Fuel Pump: eBay Motors (item 390108696313 end time May-19-10 07:35:39 PDT)
Old May 18, 2010 | 08:21 PM
dn29626's Avatar
dn29626
I like this one.
AutoZone.com | | Fuel Pump | ELECTRIC FUEL PUMP
Old May 18, 2010 | 08:26 PM
JonathanN's Avatar
JonathanN
So, are you guys saying as far as reliability goes, the stock Bosch is the way to go? As long as it'll do MORE than keep up with what I may throw at it (I don't inted to go any bigger than Stage-2's), I'm good with it. I was just wondering if there was an equal or better pump for an equal or lesser price than the stock pump. So far, I don't really see so... anybody wanna try again?
Old May 18, 2010 | 08:45 PM
JonathanN's Avatar
JonathanN
Also, another thing I wanna make sure DOESN'T happen is what's happening to poor Joe over here:
https://www.ford-trucks.com/forums/9...-srt-10-a.html
Old May 18, 2010 | 10:06 PM
  #28
Visseroth's Avatar
Visseroth
Oh I agree and I am thinking of going dual pumps as well so that if a pump fails then I can keep driving until I get it replaced and to maintain 60PSI and maintain the fuel flow in the return line as to try and remove all air from the fuel rails. I want to make my injectors last as long as possible and make my truck as reliable as possible.
Old May 19, 2010 | 01:50 AM
  #29
UNTAMND's Avatar
UNTAMND
I also have heard good things about the walbro pump, and I use them a lot on my gassers. I also use the Bosch 044 (turbo porche pump) pump a lot on high hp turbo cars. ( like supras and dsm cars and mustangs ). They are a tough pump and are rated at the most gph and psi I believe.
I'll be trying one on my truck soon. Gotta do supporting mods before I do hp mods.
Old May 19, 2010 | 05:49 AM
  #30
JonathanN's Avatar
JonathanN
What I find odd is there's this late-99 at the body shop and you can't even hear it's pump... AT ALL!!! Mine has what you guys call the "mad bees" drone. Then add that stupid chirping and it's ridiculous! Is it supposed to be that loud?
