STC fitting ??
Old May 16, 2010 | 09:20 AM
ConvertedFord's Avatar
ConvertedFord
STC fitting ??
Looking at tackling the job myself. What is the STC? Where is it Located? Do you know the part#?
Old May 16, 2010 | 10:15 AM
texans's Avatar
texans
The stc fitting, is the snap to connect fitting. It's on the hpop. I don't know the part number, but if your ok with removing the intake, and all that is included in doing that. Then you will be ok. After you get the intake off just remove the hpop cover and you will see the stc on the back of the hpop.
Old May 16, 2010 | 01:38 PM
bismic's Avatar
bismic
STC fitting part #: 4C3Z-9B246-E (International #: 1879930c91)
HPOP reservoir screen part #: 3c3z-6C683-ab
Oil Cooler Kit: 3C3Z-6A642-CA
oil drain tube: 6C3z-9T515-a (I believe this is correct for an 05)
Old May 16, 2010 | 02:08 PM
cheezit's Avatar
cheezit
all the drain tubes have been updated to the same part#.
Old May 16, 2010 | 02:15 PM
bismic's Avatar
bismic
I wasn't sure - thank you!!
Old May 16, 2010 | 02:52 PM
ConvertedFord
thanks this makes it alot easier for me. My head is clouded with new info. about this truck. I want to get it right
Old May 16, 2010 | 02:54 PM
m-chan68's Avatar
m-chan68
The high pressure oil pump on '05 to '07 trucks can be accessed without removing the intake and EGR cooler.
Old May 16, 2010 | 03:13 PM
ConvertedFord
Do i need to do the hpop bracket kit or is it included with the stc fitting/?
Old May 16, 2010 | 03:14 PM
cheezit's Avatar
cheezit
all the part you need should be included with the stc fitting assuming you get it from ford. I do not know what is in cluded with the kit from navastar
Old May 16, 2010 | 03:15 PM
texans's Avatar
texans
I wasn't sure on the 05. Thanks for the info.
Old May 16, 2010 | 03:51 PM
ConvertedFord
thanks cheez, since ur on the line. should I replace the ipr & screen that i read about. If so, where is it located? do you know the part#? what about the special tool thats required? Is this the same screen thats under the oil cooler?
Old May 16, 2010 | 04:29 PM
cheezit's Avatar
cheezit
the screen is in fact the one under the oil cooler. they do break often. there is an updated metal mesh screen from ford that is better. so far as weather you should replace parts that are not broken thats up to you.
Old May 16, 2010 | 07:02 PM
m-chan68's Avatar
m-chan68
To access the screen referenced in the post above, WILL require removal of the intake, EGR cooler and oil cooler (I usually remove the intake and EGR cooler as one piece).
Old May 16, 2010 | 07:06 PM
bismic's Avatar
bismic
The part number in post #3 is the updated screen.
Old May 16, 2010 | 07:10 PM
m-chan68's Avatar
m-chan68
The part number for the IPR valve from Ford is CM-5126 and requires a 1-1/16" open end wrench to remove/install in the absence of the proper tool. This is provided the turbo is removed.
The updated screen under the oil cooler part number is 3C3Z-6C683-AB from Ford, like previously mentioned.
