Weird question
Old May 16, 2010 | 02:39 AM
LIF150's Avatar
LIF150
Weird question
Hey yall,
So a rather frustrating thing happened today... I was working on my brakes replacing the lines at the rear on my 79 150 with my little brother helping me, simultaneously doing an oil change. While i was bending the brake lines under the truck i asked my brother to starting putting oil back in the truck and he dumped it down, what i think is the power steering inlet, but am not completely sure. Now im in a bit of a bind because im not completely sure what this inlet goes to and want to make sure. i need to know what i need to do to fix this before it screws anything up.. Its a black reservoir that says, only add proper fluid, on the right side of the engine, if i were looking at it. Does anyone have a guess at what this is? im going to get a pic up tomorrow morning, i hope, but i wanted to see if anyone has a thought at what it could be and how i should go about taking care of this..
Thanks,
Dave
Old May 16, 2010 | 03:25 AM
LIF150's Avatar
LIF150
So it is the power steering pump... What do i do now? Am i screwed?
Old May 16, 2010 | 04:37 AM
brownfoot's Avatar
brownfoot
how much oil?
couldn't have been a full quart, it would overflow..........
remove the return hose and let it drain, then refill with the proper power steering fluid
doubt it will hurt anything or ever be noticeable, other than the mess
Old May 16, 2010 | 08:38 AM
mikeo0o0o0's Avatar
mikeo0o0o0
When you say right side, is that looking from the front of the engine?
If it's the drivers side at the front of the engine, it's the power steering pump. Motor oil, not a big deal. Pull the return line from the reservior, drain what you can, put the line back on and top off the fluid, then don't worry about it.
Old May 16, 2010 | 08:06 PM
82airborne82's Avatar
82airborne82
check it out man, Ive dumped every type of fluid immaginable into my powersteering pump and its been fine for a long time! it had problems and leaks when I bought the truck so I just dumped whatever I had lying around I finally installed a new one today and when I flushed the system there were like 3 different color fluids in there! Flush it out and put the correct stuff in and youll be fine.
runawayhound
Sep 17, 2015 01:02 PM
charles09
May 25, 2014 10:44 PM
SpartanDieselTech
Apr 10, 2014 09:41 PM
Joejustatruck
Oct 24, 2012 11:49 AM
