Help removing stud -Knuckle steering
Old May 15, 2010 | 07:13 PM
rjmay's Avatar
rjmay
Replacing steering hub and now have one stud that I coud not remove so I cut it off flush.
While trying to drill it out I broke off drill bit after braking an easy out and then the end of a small punch in another 1/4 inch diameter drill hole.
Now my titanium bits do not want to drill into this mess?
Can I torch this out or is that no good because of the knuckl or is there other suggestions?
Thanks much
Old May 15, 2010 | 09:00 PM
camodown's Avatar
camodown
Are we talking hub stud? They are tightened to the back of the hub assembly with the corresponding end put through the knuckle and fastened with a Gd10 1.4mm nut I believe. If the stud is stuck in the knuckle, there shouldn't be anything fastening it into place if you chopped either side off... I am not fully understanding what part you are trying to remove. I wouldn't put a torch anywhere near the wheel hub assembly as they are heat treated....
huntdiamondjim
Modular V10 (6.8l)
18
Nov 18, 2021 02:09 AM
Jerry Chaney
May 2, 2014 10:53 AM
slafave
Aug 25, 2010 04:27 PM
caterpillar
Feb 12, 2007 11:54 PM
canbman
Exhaust Systems
Nov 4, 2003 01:23 AM
