steering knuckle removal need help!
Old Feb 10, 2007 | 11:48 AM
caterpillar's Avatar
caterpillar
I am trying to remove the steering knuckle on the passanger side of my d60 front axle and i got the top ball joint to break free now i can't get the bottom to ball joint stud to let go i have tried rapping it with several different hammers, dead head, dead blow and 3lb mall, how the heck to i get it to break free and get my knuckle off?
Old Feb 10, 2007 | 01:16 PM
Lazy K's Avatar
Lazy K
\try a "tuining fork" type ball joint removal tool. Can be bought cheap from a tool supply store. Works every time.
Old Feb 10, 2007 | 01:20 PM
Mr. Bob's Avatar
Mr. Bob
a more common term for it is a "pickle fork"
if you google "pickle fork" in quotations, it will show you exactly what it looks like....
works like a charm, make sure you get one wide enough, there are different widths...
Old Feb 12, 2007 | 06:45 PM
Winger235's Avatar
Winger235
Pickle Fork for sure. Just did 2 f-350's about 6 months ago. That steering linkage is not cheap.
Old Feb 12, 2007 | 11:54 PM
guppy's Avatar
guppy
I have one pickle fork and its great to have around but I dont really like using it for ball joints much. I have a cheap craftsman 2-jaw puller I use on ball joints now. The puller is great for joints you dont necasarily want to replace too, like tie rod ends when you are replacing ball joints ect. The pickle fork will ruin the boots on any joints you use it on. And on really stuck joints i've set tension on the puller and then had to tap in the fork to get it to brake loose. The puller is signifigantly more expensive but I do alot of mechanics work so it is worth it to me.
Dave M
KC98072
Mar 12, 2013 01:16 PM
jruggles
Feb 28, 2013 05:20 PM
jeter
Jan 29, 2010 05:53 AM
panteramatt
Mar 23, 2008 01:02 PM
Gil Chesterton
Nov 7, 2005 11:03 AM
