stud removal
Old Nov 1, 2003 | 04:36 PM
canbman's Avatar
canbman
stud removal
i have just broken off the stud that connects the exhaust manifold to the pipe.can i drill it out and use an easy out or is the stud reverse thread .i know this is probably a stupid question but i just don't know
Old Nov 2, 2003 | 04:07 PM
ctfuzzy's Avatar
ctfuzzy
It's not left-hand threads.
HTH.
Old Nov 2, 2003 | 10:03 PM
canbman's Avatar
canbman
thanx I got it fixed
Old Nov 3, 2003 | 07:20 AM
ctfuzzy's Avatar
ctfuzzy
!! YEA !!
Removing those studs when they break off is some of the NASTIEST of nasty jobs.
. . of course, I'll bet you are verrrry well aware of that.
If you have sufficient mobility left in your hands after that job to be able to type, you must be a pretty good mechanic!!
. . mine are usually wrapped in bandages for days
Old Nov 3, 2003 | 11:24 AM
Oval_obsessed's Avatar
Oval_obsessed
I am having the same problem now. Should I heat the manifold upbefore I try the easy out? I have been soaking the broken studs with PB Blaster.
Old Nov 3, 2003 | 11:55 AM
ctfuzzy's Avatar
ctfuzzy
No. I would recommend heating JUST the stud . . if possible.
The idea being to "swell" the stud and then let it contract back to *about* normal size (thus breaking the rust bond).
Heating the manifold - effectively - would take so much heat/time that the stud would heat up also, leaving you right where you started out . . but with big parts too hot to touch.
HTH.
Old Nov 4, 2003 | 01:23 AM
jdon88's Avatar
jdon88
I just went thru this myself, broke 3 of the 4 manifold to pipe studs. I tried all the suggestions I could find in these forums including the vaunted "candle trick" but nothing worked. I ended up just drilling out 2 of the studs where they went all the way thru the manifold and used a longer bolt and nut to secure the pipes. For the 3rd stud that did not go all the way thru I just drilled the stud and tapped for 5/16" bolt. I wasted a lot of time and some money trying to remove the studs, I should have just drilled them out in the beginning.
belshe92
May 21, 2016 11:21 PM
JoeDaf
Oct 30, 2011 12:35 AM
DSMMH
Jul 10, 2010 08:11 AM
coolguy1419
May 11, 2010 06:37 PM
Bullride_101
Apr 14, 2006 09:48 PM
