95' explorer wont start
Old May 15, 2010 | 02:51 PM
Christinas ex's Avatar
Christinas ex
Pulled up, shut off truck and walked away. Alarm went crazy. I got the alarm off but now it wont start. I had a 00' that needed a chip in the key. This key has no chip. I get no power to the solenoid when the key is engaged, but I can start the truck when when I use a jumper wire. all fuses are good. not sure how to test relays. Im stuck anyone had a similar problem? any ideas or suggestions?
Old May 16, 2010 | 08:59 AM
steve(ill)'s Avatar
steve(ill)
i had something similar on a 98. Happened when the battery went WAY down and i got that alarm... I had to get a new battery... always wondered if disconnecting the battery and letting the thing set for a few minutes, then reconnecting, would trigger the computer and reset everything ???
Old May 17, 2010 | 10:08 AM
aquanaut20's Avatar
aquanaut20
Make sure your battery terminals are shiny clean and greased.....
towme
Jun 15, 2021 09:30 PM
mwalls
Feb 8, 2015 09:12 AM
MightyThor
Jan 2, 2015 10:43 AM
73watermutt
Jul 11, 2014 06:54 PM
calfed
Sep 7, 2005 07:22 PM
