Post your Timing settings
Old May 17, 2010 | 08:06 PM
  #46
Ricky B's Avatar
Ricky B
How fat are the wires, and what brand are they? If they're Bosch, s-can them and buy the 9mm's FMS from Summit..........
Old May 17, 2010 | 10:06 PM
  #47
diehardfordtruck's Avatar
diehardfordtruck
I'm gonna ask a question about the cheap spark plugs,If I go down to the local "skippy do auto parts" and ask for cheap copper plugs for my application,they are gonna think I'm crazy...So are there a part number anyone knows for the 5.8? Or are the cheapest plugs I can get the copper plugs that your referring too..
Old May 17, 2010 | 10:16 PM
  #48
Ricky B's Avatar
Ricky B
I just went down to Kragens and bought 2 8 packs of Autolite Coppers when I did mine....24's and 25's.
(don't ask me why I bought two different ranges, cuz quite honestly I don't remember)......
Old May 17, 2010 | 10:51 PM
  #49
skyfox10's Avatar
skyfox10
The wires that were on the truck were some no-name brand when I bought it. The ones I put on last week were FMS 9mm's to go with the MSD cap/rotor and coil pack I put in (all came from summit because they are a one day ship from me).
I'm just speculating that the minor improvement from the whole thing might be due to the relatively new equipment that I was replacing.
Old May 17, 2010 | 10:56 PM
  #50
skyfox10's Avatar
skyfox10
24's or 25's will work. The easiest thing to do it just tell them what you drive and say you want autolites. Then they should give you a few options, ask for the coppers.
I asked for copper autolites for my truck and they said all they had was platinums and a "resistor" plug. I asked em what model the "resistor" was and they said it was a 24. I said "well those are copper so give em to me".
I beleive 25 is classically for 302's and 24's are for 351's. But I doubt it matters.
  #51
Ricky B's Avatar
Ricky B
Originally Posted by skyfox10
The wires that were on the truck were some no-name brand when I bought it. The ones I put on last week were FMS 9mm's to go with the MSD cap/rotor and coil pack I put in.
I'm just speculating that the minor improvement from the whole thing might be due to the relatively new equipment that I replaced.
Oh hell yeah, on both accounts. But now that you have put the new.better stuff on, perhaps you should put some miles on her for a week or two before segueing into the whole 6LTU?---just so the ECU/PCM thingys don't get confused with too much new info?....
Old May 17, 2010 | 11:05 PM
  #52
diehardfordtruck
Thanks guys I have got to try this I'm an old school tuner on carbs and such...didn't think they were much you could do to these efi..
Old May 18, 2010 | 07:54 AM
  #53
skyfox10's Avatar
skyfox10
That's my official reason for not doing the timing bump yet. But unofficially, I've gotta wait till I can have someone else on hand that's done timing before to take out a little of the guesswork.
Old May 18, 2010 | 08:00 AM
  #54
darthice's Avatar
darthice
Timing is pretty much point and shoot with the light and making sure the little needle is on the right notch when the light is on that is an over simplification but true
Old May 18, 2010 | 08:32 AM
  #55
skyfox10's Avatar
skyfox10
Yeah. I understand the procedure in theory. I'd just like to have someone hit me on the back of the head before I screw something up. Reading on FSB, I've seen guys count 10BTDC as 0 and go a total of 23.5 degrees over. Just paranoid I guess.
I don't even know if my timing light works. My dad has had it in his garage for years because one of his old employees left it here.
Old May 18, 2010 | 04:10 PM
  #56
mprice's Avatar
mprice
Even WalMart carries the copper AutoLites
Old Aug 26, 2010 | 02:13 PM
  #57
skyfox10's Avatar
skyfox10
Finished Reading all 95 pages of the FSB thread. I gotta say, there's a lot of good stuff there.
Old Aug 26, 2010 | 02:18 PM
  #58
mprice's Avatar
mprice
Maybe this should say "Even SOME Wal Marts ...". Everyone had #25s for the 302 but it took 4 stores before I found 4 2-packs of the #24s I needed for the 351.
Old Aug 28, 2010 | 02:46 PM
  #59
skyfox10's Avatar
skyfox10
Well, finally adjusted the timing to 13°. Truck seems to run exactly the same. But I'll try it for awhile and see.
Old Aug 28, 2010 | 02:49 PM
  #60
Dutter's Avatar
Dutter
mines set at 13.5
