Post your Timing settings
Old May 16, 2010 | 11:05 PM
  #31
Ricky B's Avatar
Ricky B
Originally Posted by MrRogers
You fellas got me paranoid. So is the Mallory Ignition coil I got gonna be good enough (51k volts, .2 ohms) and the MSD 8.5 mm superconductor wires gonna work? Sorry, newbie here. btw ricky, you're right. them fellas are a helluva resource. thanks
I used the MSD #8227 coil and the Ford Motor Sports 9mm wires myself----but I'm thinking that your stuff is probably even better than my stuff, so yeah, just do it.......
  #32
skyfox10's Avatar
skyfox10
I would say that the 51k coil should be fine. Most guys doing this mod are only going up to 48k. But take it for what it's worth, I'm learning a lot and I'm only on page ten of that FSB thread.
As per the wires, refer to the previous paragraph in this post.
Old May 16, 2010 | 11:17 PM
  #33
MrRogers's Avatar
MrRogers
right on gentlemen...let us know how yours turns out
Old May 17, 2010 | 03:52 PM
  #34
skyfox10's Avatar
skyfox10
Got a set of autolite 24's to throw in when I get home. Should only be a matter of minutes till I can get out of here. I thought my old plugs were platinum, after referencing autolite's website, the app24 is a double platinum plug.
After all this, I'm a master at changing my plugs. I can do all 8 in a snap with one deep well socket and a 4" extension.
Old May 17, 2010 | 03:59 PM
  #35
Ricky B's Avatar
Ricky B
Take some advice form an olde guy, who used to have a 911S---you want to take your time on these.
And please, don't even bother asking me how I came to this conclusion.........
Old May 17, 2010 | 04:14 PM
  #36
darthice's Avatar
darthice
I think i will do the six liter mod tonight i already have the high performance stuff on the motor just gotta gap the plugs and reset the timing to around 13*
Old May 17, 2010 | 04:33 PM
  #37
Ricky B's Avatar
Ricky B
Did you get a good cap and rotor as well? And what wires were you gonna use (were yours the pricey MSD's?)...........
Old May 17, 2010 | 04:48 PM
  #38
darthice's Avatar
darthice
Yes and yes from Oreilly Auto Parts MUAHAHAHAHA lol
  #39
bladez51's Avatar
bladez51
Very true and wise words.... I suggest adding a 4" long piece of 1/4 I.D. fuel line to your tool kit. Insert the end of the spark plug into the hose until pretty snug and use it as an extension to get the plugs started. Fixing cross-threaded holes is a huge PITA and expensive too...
Old May 17, 2010 | 04:49 PM
  #40
truckrider814's Avatar
truckrider814
I got mine set at 18*. And yes spout was out.
Old May 17, 2010 | 04:56 PM
  #41
Sbrown's Avatar
Sbrown
I have mine set at 15* My truck runs like poop when I have it set at 10* I also have done this so called "6 liter mod" with msd cap, rotor and taylor wires
Old May 17, 2010 | 05:03 PM
  #42
Ricky B's Avatar
Ricky B
Jfc, I would have thought that that's not even possible---any chance your harmonic balancer has taken a little stroll over the years? Cuz I've heard that because there (used to be?) a rubber spacer/dampener thing behind them that over a period of time they have a tendency to move a bit in one direction or another.
Just a thought...........
Old May 17, 2010 | 06:59 PM
  #43
truckrider814
Sorry apparently my computer messed up it was suppose to say I also have a cracked manifold an a miss an something wrong with my egr
Old May 17, 2010 | 07:51 PM
  #44
skyfox10's Avatar
skyfox10
I start every one by hand. Then use the socket & extension to hand tighten. I go less than 1/4" turn with a ratchet and I'm done. No crossthreading here.
Old May 17, 2010 | 07:53 PM
  #45
skyfox10's Avatar
skyfox10
BTW, truck runs better now. Took care of the problems I was having. The coppers are gapped @ .055 and it runs very closely to how it ran before I started messing with the ignition. The truck has always had a week spot at the right RPM if you get on the pedal just shy of enough to make it shift. It seems like this has improved slightly after beginning on this whole endeavor..
This truck had a new cap/rotor/wires on it when I bought it two years ago though.
