Brakes
Old May 14, 2010 | 07:27 AM
merdsue's Avatar
merdsue
Brakes
anyone with info on front brake rotor torque for 2005 f-150-can't tighten to specs and still turn rotors
Old May 15, 2010 | 11:03 AM
powersmoked's Avatar
powersmoked
Create a better profile of your truck. ie. look at mine.
Do you have 2wd? is it a regular wheel bearing setup? what torque are you using?
Old May 16, 2010 | 02:00 PM
BrianA's Avatar
BrianA
I believe the proper value is 295-300 lb-ft.
I know from replacing my 05 rotors 5 years ago, the spindle nut requires significant force to remove and significant force to tighten to spec.
If you can't turn the rotor at 300 lb-ft torque on the spindle nut, something is wrong.
mich800
Nov 5, 2010 10:24 AM
carbonmetallic
Feb 6, 2009 07:21 AM
haroutd
Nov 27, 2002 10:05 AM
troysbowman
1978 - 1996 Big Bronco
Sep 27, 2002 04:57 PM
