BOOST?????????HELP!!!!!!!!!!!!
Old May 14, 2010 | 11:58 AM
CSIPSD's Avatar
CSIPSD
Are you sure the chip is connecting to the PCM? Are all the contacts clean?
Old May 14, 2010 | 07:12 PM
SLAMMIN 22's Avatar
SLAMMIN 22
Ok guys took out boost fooler and changed guages still same problem I drove my own truck today with the same set up and it seems to run alot better than this one they were about the same performance wise so i guess it is not running the best any ideas on a leak detector what do you guys use????
Old May 15, 2010 | 05:14 PM
SLAMMIN 22's Avatar
SLAMMIN 22
Just an update built a leak detector and found the problem one of his boots had a hole on the back side of it new boot and its running fine THANKS for all the info.
Old May 17, 2010 | 07:13 AM
03_PSD's Avatar
03_PSD
good deal, that leak detector is very handy!
Old May 17, 2010 | 08:03 AM
megawatt00's Avatar
megawatt00
Glad she is all set! Thanks for letting us know where the problem was.
snakedoc
Apr 5, 2013 02:43 PM
betrayz
May 27, 2012 01:52 PM
TennesseeMustangPerf
Apr 13, 2010 12:44 PM
hndacr
Jan 18, 2010 07:42 PM
gmm
Mar 6, 2009 02:50 AM
