HPx and FRx
Old May 12, 2010 | 11:00 PM
JonathanN's Avatar
JonathanN
HPx and FRx
I'm rotten with the search feature... so if there's good threads on this, pass them on. Otherwise, what can you guys tell me about the above? I wanna make mine... my dad has the machine to make the high-pressure hoses and I don't see why the FRx would be hard. I wanna know what the fitting sizes are and where they go, what kinda hoses and fittings, ALL that good stuff! Diagrams and pictures would be AWESOME!!! Also, I'm planning on doing the in-tank mods (removing the mixer, extending the return tube) as well as replacing all the quick-disconnects, adding an in-line fuel filter and deleting the fuel bowl. I would like to do all this soon because it looks like I'm gonna be rebuilding my HPOP and I would like to at least get the HPx anf FRx done while I've got the top of the engine torn apart. Thanks guys!
Old May 13, 2010 | 08:56 PM
JonathanN's Avatar
JonathanN
BUMP!!!
Old May 13, 2010 | 09:15 PM
CSIPSD's Avatar
CSIPSD
IMHO... Save your time... And your money...
Old May 13, 2010 | 09:17 PM
JonathanN's Avatar
JonathanN
Well... I don't mind the time. I like to make my stuff though and I was hoping to save a few bucks by making it. I'm just a college student so I don't have the money for it.
Old May 13, 2010 | 10:44 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I will be installing the FRx soon, once my turbo is back from the shop. The FRx is a sweet piece of work, the engineering is done, and it is only $140. That should be conclusive. But if you have more ability and time than money, make a full regulated return set up, not an FRx clone.
Old May 13, 2010 | 11:21 PM
JonathanN's Avatar
JonathanN
Some drawings, specs, and info would be great. i have more time than money right now and I'm capable of making this stuff... I just need some help in figuring it out.
Old May 14, 2010 | 08:06 AM
clux's Avatar
clux
Here's a parts list for a full regulated return fuel system:
https://www.ford-trucks.com/forums/4...ml#post3440544
And the HPX fitting are #5 ORB (1/2" straight cut threads).
Old May 14, 2010 | 11:06 AM
JonathanN's Avatar
JonathanN
Where are the ports for the HPx? I'm just trying to get this straight. Thanks for the FRx thread... I'll read it when I've got time.
Old May 14, 2010 | 11:08 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
This may help you.
Riffraff Diesel: HPX Instructions
Old May 14, 2010 | 11:09 AM
JonathanN's Avatar
JonathanN
Originally Posted by Riffraff Performance
PERFECT!!! Thanks, Clay... reps to you!
Old May 14, 2010 | 11:14 AM
JonathanN's Avatar
JonathanN
Do you have the same thing for the FRx, Clay? That was VERY helpful!
Old May 14, 2010 | 11:27 AM
JonathanN's Avatar
JonathanN
All the ORB's I've seen are even numbered... could you give me some specifics about them?
Old May 14, 2010 | 11:55 AM
clux's Avatar
clux
I believe o-ring are sized in thenths of an inch, so a #5 ORB is 1/2", a #10 ORB is 1".
A #5 ORB is 1/2" with 20 TPI straight cut threads.
Old May 14, 2010 | 09:07 PM
JonathanN's Avatar
JonathanN
Funny... both the guys at Napa and CarQuest said that it was 16ths of an inch. i.e. #5 + 5/16". The guy at CarQuest makes custom hydraulic hoses and I can get the whole assy. for my HPx for just over $20!!! I'm doing that when the HPOP comes out... now, to figure out the FRx. Does that also have to be done while the top is torn apart?
Old May 14, 2010 | 09:53 PM
clux's Avatar
clux
They're thinking of AN (army/navy) fittings.
