Why run a regulated return style fuel system????
I see where some of you are running a regulated return style fuel system. Why? What's the advantages? Is it just to purge air out? Anybody have a parts breakdown and maybe a simple diagram. I may already have the regulator I need laying around if it's similar to the one on the racecar.
Thanks.
The design of the PSD fuel supply allows a lot of air into the fuel stream before it even gets to the injectors. The fuel rails dead end and any air that get's introduced to the fuel rails must exit through the injectors. For me that is unacceptable. Can you think of any good reason to have air in your fuel at 20,000 psi?
Ultimatly it's your decision on where to put your money. The idea that I came up with will set you back about $100.00 and a couple of days scrounging up the proper NPT fittings, fuel line, and modifying the fuel supply. But once done, I am confident you'll wonder why you waited so long. The engine loses most of that injector rattle and replaces it with a nice diesel growl.
Thanks.
I think I still have the parts list, I will try to post it later. Just about everything can be purchased at jegs.
I have a nice Barry Grant return style fuel system here in the garage but it's for the racecar. I'm guessing I just need a return style regulator, press gauge and the knowhow of where to plumb what?
Thanks. The air explains why everyone's PSD sounds different. I hear 3-4 different ones every week (different friends) and they all sound different.
Does anyone have a drawing of how everythings connected?? I learn best by picture.
Thanks.
Thanks.
https://www.ford-trucks.com/forums/s...d.php?t=260173
Diesel Innovations also has a good diagram in their install instructions for their regulated return system. It should be available on their website.
Here are the parts I used. Basically the same as DI's kit. You can get most everything at Jegs except where noted.
Adapters:
(2) 1/8 npt x #6 Straight
(3) 1/8 npt x #6 45 deg.
(1) 1/8 npt x #6 90 deg.
(1) 3/8 male compression x 1/8 fpt 90 deg. (hardware store item, this connects directly to the factory return line without cutting, see my gallery for pics)
Hose Fittings:
(5) 6AN Straight
(2) 6AN 90 deg.
(3) 6AN 45 deg.
Completed hose configurations:
•8" hose w/#6 straight and #6 90 deg.
•12" hose with 3/8 male compression x 1/8 fpt 90 deg. to 1/8 npt x #6 adapter to #6 straight other end #6 straight (pic in my gallery if that's confusing)
•15" hose w #6 straight and #6 45 deg.
•22" Hose w/ 2 45 deg. fittings
•26" hose w/ #6 straight & #6 90?
If you want the regulator anywhere other than where I mounted mine, the hose lengths will be different. The lengths are measured from end of the fittings.
Other
• 10' 6AN braided steel fuel line
• Heat wrap (to cover line near turbo/exhaust
• Regulator 2 in, 1 out with gauge port, like this ( http://www.jegs.com/webapp/wcs/store...tegoryId=19931 )
• Pressure gauge
• 3/8 compression cap for factory regulator (others call for 5/16, that would not fit mine so check first) I had a hard time getting a seal on this so I bought a replacement cap for the regulator here http://www.dieselinnovations.com/di....products&cat=2 (scroll down)
• high temp pipe dope
• #6AN Wrench (nice to have, doesn't mar the anodized finish)
• bracket for regulator (I used 2" aluminum)
If you have these parts and follow these directions here, you should have no problem.
http://www.dieselinnovations.com/di.php?page=techinfo
I capped off the factory regulator, others gut the factory regulator and tie factory return (with a small orifice) into the external regulator return. The idea is to eliminate any air in the filter housing. Check out jtharvey's, he did a nice job. If you want to do it cheaper, find Kwikk's method. Several people have done this mod differently, and combined designs so do some searching here is a thread to look at. https://www.ford-trucks.com/forums/s...d.php?t=442115
The one real PITA is the driver side rear, very hard to get to. If you can get the down pipe off that makes it much easier, otherwise loosen it. If you have any questions, let me know and I will do my best to answer them. I have several pics of system in my gallery.
And new injectors are inexcuseably expensive.
