Sponsored by: Real Truck
Is this true??
Old May 12, 2010 | 09:07 PM
jpa's Avatar
jpa
Is this true??
Was looking at 2011 Ford trucks. Was telling the salesman about the expense of maintaining a Diesel engine. He said it's worse on these 2011 Diesel's. Said there's a tank on top of the fuel tank that needs refilled each oil change. Some kind of liquid that mixes with the Diesel fuel. Pricey!!
Anyone know about this??
Old May 12, 2010 | 09:22 PM
radzer0's Avatar
radzer0
The fuel economy savings by using the DEF (liquid) over using a full EGR will save you a few dollars every oil change.
There is something like 1.5-2MPG to be gained by using the DEF. So just figure that out over time what you would save and figure around $20 to fill the DEF tank every 7500miles.
Old May 12, 2010 | 09:27 PM
jpa's Avatar
jpa
DEF tank
If it's only 20 bucks to fill the DEF I can live with that. I thought it was a lot more.
Ugh, what does DEF stand for??LOL Salesman told me but I forgot??
Old May 12, 2010 | 09:31 PM
radzer0's Avatar
radzer0
Diesel exhaust fluid.
Its around $3 a gallon. And being most newer diesels even some large semis are going to be using it (with some being over 50gallons on board) Some of the bigger gas stations by highways are going to put it in a pump like fuel. Which could bring price down more.
Old May 12, 2010 | 09:32 PM
radzer0's Avatar
radzer0
Also it doesnt mix with the fuel. Its a seperate tank and its sprayed into the exhaust after the turbo and it converts the bad stuff to not as bad stuff. Forgot what exactly it turns it into. You can read alot if you search for DEF
Old May 12, 2010 | 09:37 PM
ColdH2O's Avatar
ColdH2O
DEF: How it works in the 6.7L
A good primer on Diesel Exhaust Fluid and how it works from Ford:
http://media.ford.com/images/10031/S...rtreatment.pdf
Old May 13, 2010 | 01:30 AM
TennesseeMustangPerf's Avatar
Wonder if they will make a pre-2011 retrofit kit?
Old May 13, 2010 | 06:09 AM
jd58980's Avatar
jd58980
It mixes with the NOX (bad stuff) in the exhaust and chemically breaks it up into Nitrogen and Oxygen (Good Stuff).
That is the simplest of terms...
985diesel
Aug 27, 2014 05:07 AM
Bugs49
6.7L Power Stroke Diesel
661
Jun 6, 2013 06:54 AM
kabur66
68
Mar 15, 2012 04:50 PM
White Knight 2011
31
Jul 13, 2010 04:04 PM
Kookadala
May 22, 2009 12:48 PM
