Sponsored by: Real Truck
fuel tank upgrade
Old Aug 26, 2014 | 07:41 PM
985diesel's Avatar
985diesel
fuel tank upgrade
Has anyone changed out a fuel tank on a 2011 or newer 6.7. I would like to put a stock 37.5 gal tank in, what all do i need to do. I looked at buying a after market tank but dont want to spend the $$$. About the put the dpf delete on. do that help with space
Old Aug 27, 2014 | 05:07 AM
Just Strokin's Avatar
Just Strokin
I have replaced my stock 37.5 gal tank in my 2015 CC LB 6.7L with a Titan 65 gal tank. Most of the aftermarket tanks are designed to fit stock location and use straps that bolt to the stock locations. Installing a tank not designed to fit the stock location might cause more problems than worth in the long run. Be safe and bite the bullet to do one time big spend to get a tank designed to fit and avoid a catastrophe down the road if your "hope-it-fits tank" fails.
Desert Dave
Jan 24, 2019 08:31 AM
bell47man
2014+ Transit
Nov 12, 2015 12:13 AM
MentalState
Feb 26, 2009 06:17 PM
f1001978
1978 - 1996 Big Bronco
Mar 28, 2004 03:14 PM
BTW
Oct 10, 2003 06:19 AM
