Back Glass removal?
Old May 12, 2010 | 09:02 PM
Midwest Dually's Avatar
Midwest Dually
Back Glass removal?
This is pretty simple, but my memory isnt so hot on this..
Back glass removal, pull the weather stripping up and away from the inside of the cab, and push the glass out the back, or pull the weather strip up and away from the cab, and push the glass to the inside?? Any tips too while we are at it?
Old May 12, 2010 | 09:12 PM
fordpride's Avatar
fordpride
Hope this helps try not to damage the seal
remove all the plastic trim from around the inside of the cab. lift up lip of the seal on the inside of cab and insert 1/2 rope all the way around glass. push outword on upper corner of glass and work around the top as it comes out.
reinstall; install 1/4 rope in channel of seal all round glass but have about 6+ inch's hanging down of rope(best spot in a corner), where they come together. sit bottom of seal on bottom of lip of cab with two hang rope on the inside of cab. spray seal with some WD40. as you pull inward on the rope, it will pull the lip of seal over metal lip of cab.
Old May 12, 2010 | 10:34 PM
Midwest Dually
Hmm.. Well now.. That rope idea sounds spectacular! I will give that a shot tomorrow! Thank you!!!
Old May 12, 2010 | 10:49 PM
chicagodragon's Avatar
chicagodragon
i did it with sting line. as long as someone is outside to put pressure on the glass, its easy
Old May 13, 2010 | 12:20 AM
Midwest Dually
I thought it was.. It has been seriously forever since I played around with the back glass on these trucks, and since it has been, things were slipping my mind on that! LOL!
I wanted to see about getting that back window out of my donor truck, and perhaps even thrown in mine, since I have the solid glass window, and the donor window has the slider.
So I will go play with some rope tomorrow! LOL!
Old May 14, 2010 | 01:47 AM
Midwest Dually
Worked like a charm... Out in under 5 minutes! Great assist! Thank ya!
Old May 14, 2010 | 08:24 PM
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
Hit back window w/ hammer, pick up peices w/ shop vac, add one tube of super glue & reinstall LOL.
But seriously what fordpride said. And lots of soapy water. Soapier than bubble wand mix.
Old May 14, 2010 | 09:17 PM
fordpride's Avatar
fordpride
Great to here at least some advice i have is helpful
learpilot
Apr 11, 2009 11:35 AM
nkosi6
1997 - 2003 F150
Jan 10, 2006 04:19 PM
muckypaws
1978 - 1996 Big Bronco
Sep 28, 2005 01:40 PM
tom2131968
22
Nov 20, 2004 10:33 AM
bigric
Oct 13, 2004 09:51 PM
