6637 Filter Cross Reference Questions
Old May 12, 2010 | 03:16 PM
jpcjguy's Avatar
jpcjguy
Hi all,
So I have been reading all about this filter mod. Great stuff! But I have some questions....
B085011 is the Donaldson part number
6637 is the Wix/Napa part number
Some have stated that they are not the same filter - Donaldson is water resistant where Wix is not.
So Napa sells the 6637 for 58.49.
I put in B085011 in the search on the Napa site and it came back as "TWD B085011" - for 43.99. Is this the actual Donaldson filter? Napa guy did not know. Link to description on Napa site : http://www.napaonline.com/Search/Det...011_0000999999
TWD B085011, if it is the correct one ( and "better" than the 6637) is the same cost as the 6637 from FleetFilter.com (shipped to me at a 11.72)
Can someone help clear this up??
Old May 12, 2010 | 03:18 PM
Robert6401's Avatar
Robert6401
I can help. Go to Riffraff Diesel and get his kit. It has everything you need for less than what you are talking about spending for the filter alone.
Old May 12, 2010 | 03:34 PM
tdpower's Avatar
tdpower
Like Bob said check out Clay's kit: Riffraff Diesel: RDP 6637 Filter Kit
Comes with everything you need.
Old May 12, 2010 | 03:39 PM
jpcjguy's Avatar
jpcjguy
Thanks for the link! So will this replace my K&N tube or attach to it? Wondering if I need the kit - which is $82 shipped as opposed to a $43 filter possibly!
Old May 12, 2010 | 03:53 PM
clux's Avatar
clux
The water resistant model number is for Donaldson B085046. The B085011 is exactly the same as the 6637, the 46637, and the Baldwin PA2818.
Old May 12, 2010 | 03:56 PM
ron's power stroke's Avatar
ron's power stroke
if you still have the stock horn going onto the turbo..all you need is a piece of 4" exhaust pipe to make it work...im not sure about your K&N tube..it may work..try it first..
Old May 12, 2010 | 04:21 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
X2, Clux has it nailed. The Donaldson B085046 was made for high humidity environments.
Old May 12, 2010 | 07:44 PM
jpcjguy's Avatar
jpcjguy
So here is a pic of my setup:
Are you saying take out tube to the orange connector or beyond it? Then get a pipe?
Old May 12, 2010 | 08:57 PM
deerslayer165's Avatar
deerslayer165
I had the same exact set up as you before my 6637. You can use the K&N tube, its what I use. As for the shield, I had it crammed between the shield and the battery for a while, but like i said, its crammed. So I just took out the K&N shield. Then youre all set.
Old May 12, 2010 | 09:00 PM
deerslayer165
And no you don't need to do anything with the orange boot. They were just saying that if you had the stock intake tube.
Old May 12, 2010 | 09:22 PM
pjnadon's Avatar
pjnadon
heres a link for the cross ref for the 6637
https://www.ford-trucks.com/forums/5...reference.html
And here is a link for plans to build a cold air box to replace the stock one
in post 72 mudmaker has a really good templates that you can print.
https://www.ford-trucks.com/forums/7...or-6637-a.html
Old May 12, 2010 | 09:24 PM
worm5932's Avatar
worm5932
you should do the ccv mod too.....while your in there!
Satch
Aug 11, 2020 09:42 AM
CousinCarl
May 31, 2017 09:57 AM
Karlow
Apr 30, 2017 03:48 PM
Whitey Ford
Sep 29, 2016 04:56 AM
tjbeggs
21
Jul 23, 2011 08:07 PM
