Sponsored by: Auxito
ac/heater temp control
Old May 12, 2010 | 11:12 AM
dobie98's Avatar
dobie98
Hey guys, new to this so bare with me. 98 F150 w/ 4.6 v8. My ac/heat control has stopped working in a mid range position. Have changed the rheostat on the dash panel--no luck. Any thoughts? Thanks
Old May 12, 2010 | 05:16 PM
steve(ill)'s Avatar
steve(ill)
the temp is controled by an electric motor that runs a door between the cold and hot ducts. the air is mixed to get the temp you want. if you have hot, or cold, and not in the middle, then the door must be sticking or jumping past center when stroked. I assume you are not always hot, or always cold, as the door or lever arm would be broken... take off the plastic dash panel above the trans hump, below the radio, i think you can see the motor and lever movement after that.
Old May 13, 2010 | 09:02 AM
dobie98's Avatar
dobie98
Thanks, Steve; will give it a try.
vettman
Apr 1, 2015 01:07 PM
jdw1
Nov 11, 2013 09:57 AM
aj270
Jun 3, 2011 01:44 AM
Aggie05
Nov 5, 2010 06:36 PM
Proud Veteran 87
1983 - 2012 Ranger & B-Series
Jun 8, 2008 06:51 PM
