Pulled dash to replace heater core, but..
Old Nov 5, 2010 | 04:04 PM
Aggie05's Avatar
Aggie05
The ac/heat is only blowing out of the defrost only. Where is the blend door that controls the vent/floor/defrost located at.
What could cause this problem.
Old Nov 5, 2010 | 05:40 PM
madsonp's Avatar
madsonp
Right on the interior side of the heater core. You need to pull it to get the core out. If your AC/Heat is only blowing out the defrost vent and your getting cold and/or warm are out this vent when you adjust the temperature, then your issue isn't the blend door, you most likly have a vacuum leak somewhere. These vacuum leaks are commonly either the fittings on the PCV valve or theres a small line that runs behind the battery that have been know to get worn and leak also. Check these first
Old Nov 5, 2010 | 06:36 PM
Aggie05's Avatar
Aggie05
Thanks but It fixed itself. The heater core we replaced. Think it just needed a a minute or so to build up vacuum after having the whole system tore apart for a few days.
Works fine now.
Thanks,
aggie05
mappy881
Jan 4, 2016 06:37 AM
02GrayPowerStroke
1997 - 2003 F150
Jul 28, 2015 07:37 PM
jennshusbum
Jul 26, 2014 10:07 AM
kevinwebster1
Oct 21, 2009 06:15 PM
