4.6L intake manifold swap question
Old 04-05-2017, 09:37 PM
50COE's Avatar
50COE
50COE is offline
All,
I am using a 2007 4.6L 2V engine and trans from a 2007 Crown Vic in a custom 1950 Ford COE pickup truck build that will look like my profile pic.
https://www.ford-trucks.com/forums/1...coe-build.html
The Crown Vic air intake / throttle body was initially facing directly toward the driver's side fender. It looks like I can easily reverse that to face the passenger side... but that appears to be my only 2 options
I've noticed that any of the 4.6L engines that were placed in the F-150s and Econoline Vans have an air intake / throttle body that faces directly forward.
Does anyone know of a reason why I couldn't swap my intake for one of the F-150 intakes?
I need my air intake to face directly forward. Otherwise, I have to make the cowl inside my '50 Ford COE cab much bigger than I want it to be. If I have it facing the driver's side, it affects my pedal clearance. If I have it facing the passenger's side, it will restrict the passenger's space for their feet...
Let me know your thoughts.
thank you,
--Brian
Old 04-05-2017, 09:45 PM
50COE's Avatar
50COE
50COE is offline
Pics of my installation -- 4.6L intake questions
Picture from the front looking into the cab:
I rotated the air intake 180 degrees to face the passenger side. I want one that faces forward if at all possible.
you can see it facing the passenger side in this photo also -- one that faces forward would be MUCH better for me.
Has anyone ever swapped the intake manifolds for a different one like what I'm suggesting?
thank you!
--Brian
Old 04-06-2017, 07:42 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I think the intakes are the same, it's the throttle body that's different.
Engine Intake Manifold Upper Dorman 615-375 fits Ford F-150 4.6L # 7L3Z-9424-F | eBay
Or to be more accurate, the "adapter" or whatever sits between the throttle body and the intake.
Old 04-07-2017, 08:30 AM
Conanski's Avatar
Conanski
Conanski is offline
The intake will swap as long as you get one from another 2v motor
Old 11-08-2021, 04:58 PM
50COE's Avatar
50COE
50COE is offline
I ended up keeping the same intake manifold... but made a custom adapter plate to rotate the throttle body almost 90 degrees.
The following users liked this post:
gofftwins
01-23-2008 01:23 PM
fbodyfan
1997 - 2003 F150
10-17-2005 08:57 PM
bigbad'945.0
08-09-2005 11:02 PM
drift91
11-22-2004 09:11 PM
Cybertaz126
08-07-2004 10:03 PM
Quick Reply: 4.6L intake manifold swap question
