newbie questions
Grant
Dual leaf? You mean two seperate leaf packs or two leaves?
The rear end had two pack of leaf springs one for ride and a secondary set with rubber bumpers for when loaded. I just wondered if this was stock f100?
Side note, this being my first manual steering vehicle I have learned the importance of greasing. Got under the truck and did the steering and kingpin bushings. What a massive difference in effort. I went from grinding my teeth and groaning
in the parking lot to just holding my breath
.Sadly is there anyway to do a proper greasing of the clutch linkage and shifters, My rubber bushings are gone and now my clutch pedal is squeaking on what I believe is a called a z bar. None of these parts have a grease fitting.
The second set of springs are called auxilary springs. They are not standard per say. They are quite common on trucks of this vintage and were a ford option at that time.
The clutch piviot on the engine to frame point should have a grease point on it That shold get a squirt or two every now and then. If you cant see any grease pump her till she leaks out. The Z bar itself is a simple piviot. A bit of oil in a squirt can will help the squeaking alot. Dont oil inside the housing itself though. You dont want a slipping clutch.
Yeah, greasing the rack does wonders on a manual steering vehicle.
The disc brakes for a 64 F100 are different. Type ECI or speedway motors 1964 disc brakes into google and go from there.
Fits: 1961/64 F100/750 / 1961/69 N500/700.
MSRP each: $3.33 // FTE Ford Dealer Parts Dept sponsor PARTSGUYED.COM price each: $2.40.
4 of these bronze bushings are required because they are split...so two are used above, two below on the inner/outer pivots the Z bar attaches to.
Look closely at this bar, it is supposed to have a place for a Zerk (grease) fitting to thread into. Ford put a rubber plug in the Zerk fitting hole on the assembly line...it may still be there.
The reason I know there's (supposed) to be a grease fitting there, is because of the following:
358979S .. Felt Washer / Available from Ford
MSRP each: $1.60 // PARTSGUYED.COM price each: $0.96.
These felt washers are used to retain the grease where the bronze bushings ride on the pivots. They fit into the ends of the Z bar.
4) B7C2461A .. Clutch & Brake Pedal Shaft Nylon Bushing / Available from Ford
Fits: 1957/64 F100/750 / 1965/66 F100/250 / 1965/67 F350/1100.
MSRP each: $5.00 // PARTSGUYED.COM price each: $3.60.
The brake/clutch pedal's are suspended from a bracket under the dash. The shafts of these pedals have split nylon bushings on them, two for the clutch, two for the brake.
After awhile, the bushings fall apart. When this occurs...you think you have mice under the dash, because the pedals go squeek...squeek...squeek!
Another thing you want to check are the two shouldered nylon bushings on the clutch rod that attaches to the clutch pedal's bellcrank, then passes thru the floor and attaches to the clutch equalizer Z bar.
When these bushing fall apart, the 90 degree ends of the clutch rod begun to crack...eventually snap off. Not pleasant!
The rod is obsolete, no one has any. The bushings (COAZ7526B) are also obsolete...but, 330 are still available from Ford Dealers, obsolete parts vendors.
Sources with the highest inventory:
GREEN SALES CO. in Cincinnati OH has 37 = 800-543-4959.
PARTS INTERNATIONAL in Farmers Branch TX has 50 = 888-727-0418.
PIEDMONT FORD TRUCK in Greensboro SC has 54 = 336-668-2401.
Grant
Grant
