Sponsored by: Real Truck
Multi Function Switch Box/no tail, brake or hazzard lights
Old May 10, 2010 | 09:54 PM
stevebm29's Avatar
stevebm29
Just bought a 99, 250 Super Duty 4x4, I have no tail, brake or hazzard lights. I've checked fuses etc. and everything looks OK and after searching here and on the net I see that 350's have a Multi Function Switch Box in the dash under the stereo. Is this something the 250's have? Any help appreciated!
Old May 11, 2010 | 01:06 AM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, the 250's will be identical.
The first thing I would look at is your signal flasher, followed by the multifunction switch itself. You might also want to examine the wiring going to the rear lights and trailer to make sure a previous owner has not buggered it up.
Old May 11, 2010 | 05:16 AM
stevebm29's Avatar
stevebm29
Thanx, I will do that this morning!
Old May 11, 2010 | 05:32 AM
gearloose1's Avatar
gearloose1
Bad flasher is no. 1 suspect. Just to be sure... reset the computers.
Old May 11, 2010 | 06:55 AM
stevebm29's Avatar
stevebm29
Gearloose1, I will reset computer and charge and load test battery, but I question the flasher, how would this effect the brake lights? BTW I can hear clicking at the pedal when it's pressed. Just wanna have my guns loaded when I start diagnosing! Thanx and great link you posted...........also the third brake light is working..........
Old May 12, 2010 | 05:27 PM
stevebm29's Avatar
stevebm29
So......I've reset computer, bought a new multifunction switch ( got it from napa, switch was no good as the wiper was in hyper mode and washer fluid just kept spraying! After inspecting switch it was missing 2 prongs for plugs! They did take it back $109+! ) so I got a used one from bone yard $50+ and flasher,....still no luck! I have pulled every fuse and swapped any that have to do w/ tail, brake or hazzard lights, still no luck! Beside going thru the whole wiring system anybody got any more ideas????????????
Old May 13, 2010 | 08:44 AM
stevebm29's Avatar
stevebm29
ANYBODY, ANY IDEAS!
Old May 14, 2010 | 03:34 PM
stevebm29's Avatar
stevebm29
FEI..after $100 bucks in parts the solution is that the #1 fuse/flasher fuse is loose and after tearing off the dash to change flasher that is under radio, WTF was Ford thinking except that only a tech could find it, I could hear it clicking while playing with #1 fuse. I pulled the fuse box to repair the loose connector and there is no accesing the inside of it, I put a small piece of solid copper welding wire in with the fuse and WALLAH......tail, brake and hazzard lights! I hope this helps someone as I wish someone else had gone thru this and posted their experiance, oh well I'll look for inexpensive fusebox and do it right someday!
Fordbronco1995
Jan 4, 2022 11:43 AM
mustange70
Jun 14, 2016 09:48 AM
bcamill
Apr 4, 2016 11:25 AM
mustange70
Oct 6, 2015 03:28 PM
79schaefer
Jun 5, 2015 09:25 PM
