cross member
Old May 9, 2010 | 08:48 PM
unclejunk's Avatar
unclejunk
cross member
i have a 88 f350 2wd that iam converting to 4x4 it has a zf 2wd and iam puting in a zf5 4x4 do i need a different crossmember
Old May 9, 2010 | 08:50 PM
Hitokori's Avatar
Hitokori
no sir you are good to go with the cross member u have since ur going to use a zf 4x4
Old May 9, 2010 | 10:28 PM
EPNCSU2006's Avatar
EPNCSU2006
I'm pretty sure that the 4x4 crossmember is different than the 4x2 to allow for front driveshaft clearance.
Old May 10, 2010 | 12:01 AM
Hitokori's Avatar
Hitokori
no no no no no... no the transmissions use the same cross member....
and if its not then by god its the first one i ever saw that was different between a 2wd and 4wd version beings the mount is in the same spot
Old May 10, 2010 | 02:56 AM
fordman1090's Avatar
fordman1090
Yes, there is a difference between the manual transmission 2wd and 4x4 transmissions. The 4x4 drops down slightly at the trans mount and then drops down more where the front drive shaft passes through.
The 2wd cross member goes straight across from frame rail to frame rail.
Old May 10, 2010 | 11:30 AM
Hitokori's Avatar
Hitokori
:P yup im wrong on this one lol and so was everyone else...
it drops down about 2 inches on the passengers side where is mounts to the frame then it may drop 1/4 inch next to the transmission on the drivers side
[img]http://www.supermotors.org/getfile/164388/fullsize/Bronco%20003.jpg[/url]
FullSizeBronco.com - 78 - 96 Ford Bronco offroad club, forums, tech, installs
Old May 10, 2010 | 02:20 PM
Alvin in AZ's Avatar
Alvin in AZ
Silly Hitokori, of course they ain't the same...
Everyone knows Ford never learned how to make the same part twice! ;)
Butthead in AZ
Old May 10, 2010 | 04:33 PM
EPNCSU2006's Avatar
EPNCSU2006
Not that it matters, but how was I wrong?
On an interesting note, a 5 speed 4x2 crossmember and brackets from a '95 F150 bolts into my '87 frame and mates with the '90 ZF I installed. Not bad for keeping things the same, although they did change the spacing of the transmission mounting stud slots in the crossmember so I had to buy a transmission mount (isolator) for the '95.
Old May 10, 2010 | 05:34 PM
Hitokori's Avatar
Hitokori
lol xD idk i just have to drag people down with me
any ways now that its all sorted out and we know for sure what it looks like
Old May 10, 2010 | 09:20 PM
EPNCSU2006's Avatar
EPNCSU2006
Gotcha....
Those pictures are worth 1000 words, thanks for finding them
Old May 10, 2010 | 09:25 PM
unclejunk's Avatar
unclejunk
thats what i thought good thing i didnt save it dodododod!!!!!!!!!!!!!
Old May 10, 2010 | 09:48 PM
fordman1090
Ya when i did the 2wd mazda5 to ZF 4x4 swap i found a mazda5 4x4 cross member just in case i needed it. I ended up using it. I think that the 2wd cross member raises the trans/tcase so much that it may contact the floor board. But i didn't try it. I still have the 2wd cross member sitting in the garage, along with a small block 2wd ZF that i can seem to get rid of.
Bennisriley
Dec 15, 2016 07:03 PM
jg96powerstroker
21
Oct 26, 2015 09:25 PM
seafire
21
Nov 28, 2010 05:05 PM
new2fordf250
25
Dec 26, 2009 11:56 PM
Supercouper
Oct 5, 2009 02:45 PM
