Sponsored by: Real Truck
Slight-Rust Touch Up's. Need Tips or How-To's.
Old May 12, 2010 | 03:03 PM
ke6zmy's Avatar
ke6zmy
Originally Posted by motor-man
Anyone??
I'm mostly concerned about the painting driveshaft. Is this a bad idea??
Paint? I would say ok. The other products that have been mentioned? No.
Too much of a chance of being out of balance. Even a little bit. The money? Questionable. It is not like your ds is going to rust through. That you would have to replace it because of rust. And, if you did, would it offset the cost of the bearings, gears, and U-joints you will have to replace if the applied prodiuct is even a little heavy, on balance, on one side or the other.
Clean it up, apply some Rust-o-leum. If you clean it up with some warm water and soap, apply some Rust-mort to convert the ramaining rust, if any, to primer, and then apply some paint it will last a long time.
Old May 12, 2010 | 04:14 PM
motor-man's Avatar
motor-man
Great, thanks alot. I'm not concerned about it rusting through, just more concerned about the look.
I'm going to use some duplicolour bedliner for my radius arms and hitch point, and maby even my front and rear diff covers...Probly some other stuff I'll end up doing as well. And for the drive axle I will just use normal paint.
What's the best paint for this that I can pick up at the local store? Thanks.
Old May 12, 2010 | 06:14 PM
clintusaf's Avatar
clintusaf
I would use the Rustoleum Textured paint that i recommended before. just picked myself up some at wally world today and plan on going crazy with it on my truck here soon.
Old May 12, 2010 | 06:18 PM
clintusaf's Avatar
clintusaf
And i know some of you guys had to read my post about herculiner on the hootus. I'm surprised no one has commented on it yet. it had me tearing up i was laughing so hard.
On Edit: i forgot to metion the hootus thread has had over 1 milllion views.
Old May 12, 2010 | 08:55 PM
motor-man's Avatar
motor-man
Awesome thanks.
But now I have had someone else tell me that even a spray paint on the drive axle may throw it out of whack, and to stay away from it all together.
Any thoughts>?
Old May 12, 2010 | 10:09 PM
clintusaf's Avatar
clintusaf
I'm not sure on that one. I dont think a very light coat would do anything, but i'm no engineer.
Old May 12, 2010 | 10:37 PM
mhoefer's Avatar
mhoefer
The drive axle itself is not an issue, the driveshaft is a rotating mass, out of balance creates issues. Go ahead and rusto the whole front and rear axle and frame ect, just be sure to mask off any bolts and nuts you ever want to take apart. Cover all seals, dont paint over axle and diff cover, as these will need to be cut later when you change the diff oil. I have used rusto products on hitchs and other parts and the idea of the pre treatment is great. You will be more satisfied with this solution.
frederic
Jul 16, 2021 09:01 PM
Poppabear
Jan 12, 2011 02:23 AM
BigBlockF-250II
Offroad & 4x4
Jan 17, 2006 08:04 PM
Greywolf
Dec 18, 2003 07:46 PM
FordPerf300
Offroad & 4x4
47
Feb 26, 2003 05:25 PM
