upper filter
Old May 9, 2010 | 08:04 AM
mh5500's Avatar
mh5500
upper filter
What would cause the upper filter to be empty when you remove the top?
Old May 9, 2010 | 08:16 AM
bismic's Avatar
bismic
Are you having any issues w/ poor performance or hard starts?
There are a number of things that could cause the filter to be empty, but most of them will show up as poor performance/starts.
Also - what year truck do you have (and any mods)?
Old May 9, 2010 | 08:21 AM
mh5500's Avatar
mh5500
It' a 2003. Yes it starts and shut off about 3 time before it stays running first time you start it for the day. (once in a while it will start normal) After you start it the first time it will run and start the rest of the day. I put a new stock fuel pump on and no difference.
Old May 9, 2010 | 08:37 AM
bismic's Avatar
bismic
You may have a small air leak in the HFCM system. I would check that first - maybe make sure that the HFCM cap o-ring is not leaking for some reason.
The later year models modified the tubing from the HFCM to the secondary filter to include an "anti-siphon" loop. I suppose it was done to prevent what you are experiencing.
Old May 9, 2010 | 08:54 AM
mh5500's Avatar
mh5500
Could you put a loop in this trucks line? It didn't use to do it. But it has been now for a while.
Old May 9, 2010 | 09:58 AM
npccpartsman's Avatar
npccpartsman
The small black "stand pipe" that holds the filter might need replaced or the FP regulator spring/plunger might be leaking. I don't have a detailed flow schematic of the secondary fuel filter housing so I'm not sure that either would apply, but that's the only two places I know that fuel might go back to. Does this happen with a full fuel tank also?
Old May 9, 2010 | 12:15 PM
mackl1's Avatar
mackl1
Wonder if the sealing surface of the fuel regulator poppet valve could be damaged? Also keep an eye on your oil level to make sure the fuel is not going that way.
Read somewhere about a bubble test at the secondary fuel housing for another problem wonder if you are getting pressurized from that forcing the fuel out.
mh5500's Avatar
mh5500
Yes, doesn't matter how much fuel is in it. It does it most of the time, but once in a while it will start the first time. But not often
Old May 9, 2010 | 12:16 PM
mh5500's Avatar
mh5500
No fuel in the oil or coolant
Old May 9, 2010 | 04:21 PM
npccpartsman
I found this interesting tidbit for you also: 2005 Update Page 01 Running Updates
Seems like it must have been a common enough problem for them to re-engineer the fuel filter bowl and line.
Note that it is NOT backward compatible for older year model trucks.
My suggestion would be to let the fuel pump "cycle" once or twice upon first start of the day, just like you were changing filters OR add a check valve inline to prevent siphoning.
Old May 9, 2010 | 06:57 PM
cartmanea's Avatar
cartmanea
Make sure your upper filter cap is not cracked and that it is fully seated and sealing with the o-ring properly.
Delta2142
6.4L Power Stroke Diesel
Apr 21, 2013 12:34 PM
Irish816
May 14, 2012 11:01 PM
sswebber
Nov 3, 2010 06:09 PM
jamie7375
Mar 19, 2009 01:46 AM
Skweeker
Jul 5, 2007 11:39 AM
