frame diferances between 1970 and 1979 are there any??
bump front suspension usually bolts up to dents from F100 to F100 (have to use the whole unit though, the steering is a little different), but I must admit, I'm not sure about the F250 series stuff. I do know the bump front suspension stuff is generally considered inferior to dent front parts when talking about the F100s. The front sway, if it's like the ones I've seen, will only work if you use the bump radius arms. The rear may give you problems too, as the rear frame is 4 inches different.
I'm having problems getting a front sway for mine (for cheap enough) because I need the brackets that mount to the radius arms too. My buddy gave me the rear bar, u bolts, plates and links, they came off an '87 F150, and match my 8.8 rear axle. I got one from a '91 F250 too, but it's too big. I like the front bar to be a little bigger than the back one.
Hi I have a 67 Ford f 100 want to put on a 77 frame and don't need the gas tank leaving the factory
Not enough room under the frame for a factory fuel tank, that's my biggest problem. The cab and front end is bolt on. Even the rad core is the same (may need a few holes drilled). The bed will go on, but you'll need to fab. I believe the tire will sit off in the rear wheel well. The rear axle track is more narrow than the front. There is a particular web site that has all this info in detail, their idea is to put the 70 stuff on the 78 frame though. It's a great site, but I believe there is a feud between this site and that one. First part "Ford" Second part "ification". I'm Lady Killer up there.
Chevmn56
10-09-2017 02:24 PM
70FE250
05-06-2016 10:07 AM
orangeford
10-27-2001 06:47 PM
