Stalling Problems
Old May 8, 2010 | 07:48 AM
joey390burnout's Avatar
joey390burnout
Stalling Problems
Hello,
I have a 1987 ford F150 5.0 EFI. When i First crank it up it will rev up too 1500 Rpms for about a second then Stall out. I Tried resetting the computer and Putting a new Coolant sensor, but nothings helping. When its warmed up it wont stall, just After its been sitting for a couple hours. Does anyone no how to fix this issue?
Old May 8, 2010 | 02:29 PM
ken2400's Avatar
ken2400
Vacuum leak? Don't know if this year has the vac cans. They look like coffee cans and like to rust out. Replace or try to repair with silver duct tape.
What are the codes you found?
Good luck and keep us posted.
Old May 10, 2010 | 10:27 AM
joey390burnout
All vacuum Hoses are connected, and vaccum can is fine. I still cant figure out what the cause is!
Old May 10, 2010 | 02:59 PM
rla2005's Avatar
rla2005
Check for stored codes and also check your fuel pressure. How old are the plugs, wires, cap and rotor? Same for the fuel filter?
Old May 10, 2010 | 04:41 PM
bigalows's Avatar
bigalows
What do the vacuum cans do? Other then just hold vacuum?
Old May 10, 2010 | 05:49 PM
rla2005's Avatar
rla2005
Hold and supply vacuum when manifold vacuum is low, i.e. accelerating, going up a long hill, etc. They supply vacuum to components that rely on vacuum to operate such as the dash vents, egr, TAB/TAD and cruise control if it is not an electronic servo type controller.
Old May 10, 2010 | 08:55 PM
joey390burnout
I just replace the plugs, wires,cap and rotor. How do i check the codes?
Old May 10, 2010 | 11:52 PM
rla2005's Avatar
rla2005
Warm up the engine and transmission then follow this procedure: How To Run a Self-Test
If you have a difficult time counting flashes consider this code reader: Equus 3145
jduggan43
Sep 30, 2013 10:29 AM
Peterbilt376x
Mar 3, 2012 02:26 PM
sterling541
Mar 30, 2011 07:06 AM
