Broken down. Need quick help
Old May 7, 2010 | 06:57 PM
nissandoc's Avatar
nissandoc
Neighbors father-in-laws truck wont start, he just called me to come look at it. Need ideas on what to look at first. I'm not as familiar with the 6.0's so some input would be greatly appreciated. I think its an 05.
Old May 7, 2010 | 07:00 PM
69cj's Avatar
69cj
No offense but you give next to no info. You need to check first for codes and also give details on the truck. Maint. details, type of filters and mods.
Old May 7, 2010 | 07:04 PM
nissandoc's Avatar
nissandoc
Completely stock truck that is maintained well. He pulled in to the campground and shut it off to check in, wouldnt start after that.
Old May 7, 2010 | 07:05 PM
npccpartsman's Avatar
npccpartsman
I would look for the presence of fuel in the secondary fuel filter under the hood. On an 05 I would suspect the snap to connect fitting on the high pressure oil pump or some kind of high pressure oil leak. The truck has two oil systems---just because he may or may not have oil pressure while cranking on the dash gauge he might not have HPO pressure. Get it code scanned if possible. Check the FICM repair section also. There is a TON of no start diagnosis in the tech folder also.
Old May 7, 2010 | 07:06 PM
JaySVX's Avatar
JaySVX
by won't start you mean won't turn over, or turn over and not fire, or sputter and die. is there electrical power, are lights dim. if he sticks wires to the positive and negative terminal of the batteries, then touches the wires to his tongue, how does he feel? This is what he meant by details.
Old May 7, 2010 | 07:07 PM
william_04_x's Avatar
william_04_x
Here's bismics no start checklist..
Old May 7, 2010 | 07:09 PM
69cj's Avatar
69cj
If it should start after cooling off, 99% it's the hpop stc fitting and you are not going to repair that at a campground.
nissandoc's Avatar
nissandoc
Sorry, it does spin over. I have AE and I'm on my way now. Hopefully the campground has wifi so I can check back in with you guys. Thanks for the help. Will check codes and HPOP readings first.
Old May 7, 2010 | 07:17 PM
npccpartsman
Hopefully you got my PM before you left for the campground
Old May 7, 2010 | 09:50 PM
nissandoc's Avatar
nissandoc
Ok, here's the deal. Batteries were pretty much dead from him trying to crank it so much. Hooked up AE but really couldnt tell anything since the batteries were dead, connected jumper cables to charge batteries and since I was waiting I started checking fuses just to make sure it wasnt something simple. Found fuse #39 blown. Replaced it and truck fired right up. Its listed as mirror heater but surely it powers something else. Does anyone have access to a service manual to look at the power distribution chart?
Old May 8, 2010 | 12:05 AM
cheezit's Avatar
cheezit
is the owners manuel in the truck. if so varify the position of the fuse against the diagram in the owners guide. a mirror fuse would not do that.
Old May 8, 2010 | 12:09 AM
cheezit's Avatar
cheezit
I would put the blowen fuse back in and see if that was just a fluke of luck to find a blowen fuse. when you put it back in if it still starts then its just a blowen fuse and you have other issues.
I would suspect a hpp oil leak. it will restart once it cools off.
Old May 8, 2010 | 01:22 AM
dchamberlain's Avatar
dchamberlain
Fuse #40, right next to it, is the fuel pump. That would do it. And it would be easy to miss the fuse position in that block.
Just FYI, according to the '05 Owner's Manual, fuse #39 is a 15 amp (Blue) fuse, and fuse #40 is a 20 amp (yellow) fuse.
Old May 8, 2010 | 05:33 AM
gearloose1's Avatar
gearloose1
Just a note to all of you - outstanding work!
Old May 8, 2010 | 08:34 AM
nissandoc's Avatar
nissandoc
Reps to everyone that chimed in.
It was fuse #39, 15 amp. What I'm wondering is, is there any other circuits powered off of #39. I know its not the mirror heaters cause this truck dont have them but there was a fuse there. From what I am used to seeing (Nissan) you will have several circuits powered from a fuse but the owners manual or fuse cover will list only one thing. Looking at a service manual should give you all of the items that uses that particular fuse. It may also be coincidence that it had cooled enough to start after I had replaced the fuse.
Oil is full and clean with no leaks on the ground under the truck. Do the 6.0's have an issue with internal leaks from the HPOP?
