Spyder Jr.
Old May 7, 2010 | 07:47 AM
Methodical_1's Avatar
Methodical_1
Spyder Jr.
I was looking at American Air Suspension description on the Spyder Jr. and what it does. Does anyone have this installed on their truck with air suspension? If so, what are your thoughts on it? Also, how is it installed on the truck...trying to get a visual as there's no pictures of the Spyder Jr. on the site.
Thanks...Al
Old May 9, 2010 | 08:45 AM
Oldtrucknut7077's Avatar
Oldtrucknut7077
It's basically a airline "T" union to use so you can add/remove air from the system (like a tire valve stem). It usually found under the master cylinder.
Old May 10, 2010 | 09:18 PM
American Air-1's Avatar
American Air-1
It allows you to remove a part thats prone to break...which is the plastic line union over by the brake master cylinder. The Spider jr. goes where the old line union was.
It was originally designed to be able to tie into the system to add air in case of certain failures, but if you made yourself an attachment hose, you could use the Spider Jr. and your air suspension system to pump up a flat tire, whether it be on your vehicle...or someone elses.
Old May 11, 2010 | 04:19 AM
Methodical_1
Thanks for the info.
09f250v10
Sep 4, 2015 06:19 AM
Groundpounder0331
Sep 2, 2013 12:11 PM
fordpride
18
Aug 3, 2012 09:21 PM
Ken_C
Oct 16, 2010 05:10 PM
bad12jr
Nov 17, 2009 06:28 PM
