with all the problems people have had with holleys recently i would stay away. i am very happy with my carter though. i have an old holley red and its great but iv heard the new ones have alot less quality. summit is the cheapest place iv found.
The holley pumps run a sealed motor, and are bad for the shaft seal going bad and letting fuel into the motor, frying it. The Carter pumps run a wet, permanent magnet motor, and have no such issues. They pretty much seem to last forever.
im trying this one:
Mr.Gasket Micro Electric Fuel Pump-Diesel 4-7psi 35GPH #12D
lowest price is amazon.
meets and exceeds the oem specs of the mechanical pump,so we shall see.
only around 45-50 bucks.
i run all the new lines today supply/return,both tanks to FSV.
now waiting for the new FSV to be delivered.
Holly red pump for 9 years no problems. Only 22k miles though so ask me again when I have 100k on it in 2036.
I've been running a blue on my drag bug for years never had an issue. You do have to mount them correctly with the motor vertical over the pump housing. I could only see a problem if it's mounted upside down.
