Sponsored by: Real Truck
Caliper didn't fix it
Old May 9, 2010 | 01:55 AM
redford's Avatar
redford
FTE Leadership Emeritus
If just one side is not applying brake force, take a good look at your hard lines that run down the axle tubes. That smell may be brake fluid squirting onto hot exhaust.
Old May 9, 2010 | 06:37 AM
gearloose1's Avatar
gearloose1
If your calipers have seized, chances are internally it is damaged by heat.
Replace the whole caliper with a quality new or rebuilt.
Oh. check for grease in bearings --- overheating can cause grease to melt and run out.
Replace rubber brake hoses as well.... plus rotors.. pads...
Old May 9, 2010 | 12:57 PM
wrdabney's Avatar
wrdabney
It's not that they aren't applying pressure or that they are seizing.one side just constantly apply a little pressure. I have replaced the caliper recently. I will try replacing the rubber hose first and see if that fixes it.
simulatedjim
Aug 9, 2014 07:51 PM
ilo9
Feb 25, 2010 12:42 AM
PSD4ME
Mar 23, 2008 01:16 PM
osteo16
Feb 16, 2008 12:49 AM
mustange70
Nov 22, 2004 04:47 PM
