A/C conversion kit questions
Old May 6, 2010 | 04:58 PM
Hitokori's Avatar
Hitokori
Originally Posted by truckrider814
I dunno my uncle's truck lost all it's r12 and it cost to much to get more so he just put in r134 and it worked the whole time till he parked it. I did the same thing mine had been dry for years and i put the new stuff in and it worked till i realized dad had unplugged the compressor and i plugged it back in an found it out was locked up(dad never told me) so i dunno about all that not compatible and needing to change over parts. i'd try to just put r134 in there and if it dont work nothing ventured nothing gained and a few bucks on r134 just to try.
my .02
im with him worst thing happen is it not work and have to change everything anyway
besides that its just $50 extra if it doesnt work
Old May 6, 2010 | 05:17 PM
tjc transport's Avatar
tjc transport
i ain't rite
what happens when you use the auto parts store "quick conversion" kits is called black death by A/C folks, cause after it runs for a while everything inside the A/C lines turns black just before the compressor seizes due to the incompatability of the oil that plugs up the orifice tube..
Old May 6, 2010 | 05:22 PM
subford's Avatar
subford
Most all Ford trucks came from the factory short on oil.
There is a TSB out to add more oil to them or the compressor will lock up.
TSB 97-10-5.
File Type: pdf
Old May 6, 2010 | 05:31 PM
Hitokori's Avatar
Hitokori
well hell from what everyone is saying u need a new compressor condenser drier orifice tube
xD thats pretty much the whole damn system so screw it and as far as u cant vent r-12 into the atmosphere i have a valve core remover that says different
yea its illegal and if the epa is right next to u ur going to get one hell of a fine
so the way i see it is if u try it and it tears up it doesnt matter because u have to change all of it anyway
Old May 6, 2010 | 07:21 PM
rla2005's Avatar
rla2005
Before I would waste money with a backyard R-134a conversion and risk ruining all the lines, condenser, compressor, etc. open up the system, pull the orifice tube to see what kind of crud is on it. If it is reasonably clean, install a new tube, receiver/dryer and every o-ring you can find on the a/c lines. Pump it down, make sure it holds a vacuum then install one of the R-12 drop in replacements such as Freeze 12, Autofrost, Duracool. Do some research, then pick one. Most run ~$8-12 a can.
Charge the system by weight. Then check your vent temperatures and pressures. If it blows up then you know it was a failing component not an issue of an incompatible refrigerant. O-rings run $6 for a bag of universal fit, the last receiver dryer I purchased was about $28 shipped to my door. The orifice tube was about $4 at Advance Auto. I had some leftover AutoFrost (R-406a) from another project, they originally set me back about $8 a can 7 years ago. Add in $10 for the conversion fittings. So for around $60 you can have a decent working system again without having to worry if it is going to implode on itself.
Old Jun 30, 2010 | 06:16 PM
occupant's Avatar
occupant
This is the way to go I think. The R-406a AutoFrost stuff is compatible with the mineral oils, nearly nonflammable, and it's still cheap. I'd gladly change my filter/drier/orificetube/whatchamacallit and seals and drop this into my Torino's R-12 system. My AC system WORKS, it's just not cold enough for Texas heat. Today for example, it was 70's and rainy, and it was FINE. But next week when it's sunny and 96, I might as well roll down the windows and shut the AC off.
Old Jun 30, 2010 | 08:03 PM
rla2005's Avatar
rla2005
I filled my '92 F350 with R-406a last fall when I replaced the condenser, orifice tube and receiver/drier. It works great as a drop in replacement for R-12 systems. R-406a is supposed to cool a little better than R-12, but I suspect your Torino would still need a boost with the extreme Texas heat. I was in Dallas last week, 100+ every evening!
If you do get serious with the A/C system consider using a red orifice tube instead of the factory blue. That should help you out for little cost. If your vent temps and pressures are still high you might consider a custom parallel flow condenser.
ryanr52983
Ford Truck Parts for Sale
May 16, 2017 08:20 AM
1L243
Dec 16, 2015 08:08 PM
phillip99
Dec 2, 2015 10:17 AM
lpbaca
Mar 9, 2008 09:29 PM
slcdzl
Jul 23, 2007 11:55 AM
