Vibration in overdrive
Old Jun 30, 2010 | 02:56 PM
selbona's Avatar
selbona
'95 F250, 5.8, E4OD, 2WD work truck
I"ve searched the forums and can't find anything specific related to the problem I'm having. I recently bought this truck and it has a pretty significant vibration when it shifts in to overdrive at about 45-50 MPH. Then, the vibration goes away when I get up to highway speeds (up over 55MPH). When I slow down and it down shifts, it starts up again and then goes away once it gets below 40MPH. If I turn of the overdrive, it doesn't do it at all. My first thought was the overdrive gear, but it shifts too good, I think. Anybody got any ideas? Thanks.
Old Jun 30, 2010 | 03:49 PM
Lazy K's Avatar
Lazy K
I think the first thing I would do is a tune-up. Plugs, wires, fuel filter and air filter and see if that helps.
Old Jun 30, 2010 | 06:13 PM
Connor101's Avatar
Connor101
I think its a u-joint i had this problem on my truck when i test drove it before i bought it and the guy replaced u-joint for free and that fixed the problem
Old Jun 30, 2010 | 06:20 PM
selbona's Avatar
selbona
Thanks for the help guys. I was thinking U joints at first, but I couldn't figure out why it wouldn't do it in overdrive. I already did a tune up. The only other thing I need to do that might cause that problem is change the trans filter and fluids. I just haven't gotten around to it yet. This truck sat for about three years and just got put back on the road, so I'm sure there's more that will start going wrong soon.
Old Jun 30, 2010 | 08:09 PM
rla2005's Avatar
rla2005
Sounds a lot like torque converter shudder to me. A complete fluid change and filter will most likely fix it. FYI... it takes about 16-18 quarts of ATF to completely change the transmission fluid in an E4OD.
bcrab
2004 - 2008 F150
36
Jul 19, 2020 03:33 PM
666
2004 - 2008 F150
Dec 28, 2016 07:56 PM
fordka
Oct 28, 2012 08:40 PM
