injector circlip removal?
Old May 5, 2010 | 06:12 PM
Mihylo33's Avatar
Mihylo33
How the hell do I get the metal circlips out of the injectors so I can replace the D-ring and ferrule ring?
It doesn't have ears like a standard circlip..........
Thanks in advance.
05' F250 6L
Old May 5, 2010 | 06:21 PM
cheezit's Avatar
cheezit
push the clip in towards the connector and lift up on the hard shell
Old May 5, 2010 | 09:25 PM
Mihylo33's Avatar
Mihylo33
So I push in on Circlip (#3) and lift on the copper washer (#2). Correct?
Old May 5, 2010 | 10:15 PM
cheezit's Avatar
cheezit
sorry I misunderstod the question. I have tried to get the clips out of the top. I gave up. I just used a pick to pull out the rubber o-ring.
Old May 6, 2010 | 12:30 AM
cartmanea's Avatar
cartmanea
I was told you take a sharp punch and hit the center of the clip and it will make the ends pop in.
Old May 6, 2010 | 05:01 AM
Mihylo33's Avatar
Mihylo33
Yeah i just went and bought a set of really small picks grab at them. So you have installed these o-rings (d-rings) before?
I bought a push punch as well thinking I could indent the sides a bit and grab it
Old May 6, 2010 | 06:09 AM
npccpartsman's Avatar
npccpartsman
Does removing the o-ring first allow for slack in the circlip as I see that the clip sits on something else, not directly on the d-ring. I was told they were a bitch to get out, and without having any spare new d-rings I've never tried hard.
Old May 6, 2010 | 04:17 PM
Mihylo33's Avatar
Mihylo33
Someone just told me to get a small socket that fits inside the injector but big enough to catch the snap ring and tap it. It gives some slack to get behind andpull out the clip. Going to try it now and see how it goes.
Old May 6, 2010 | 04:24 PM
cartmanea's Avatar
cartmanea
You can also replace the o-ring without removing the clip, but it takes some care.
Old May 6, 2010 | 05:33 PM
Mihylo33's Avatar
Mihylo33
OH Damn! Didn't notice it before because the back injector was the one blown out. I actually started replacing just the o-rings and noticed this. It came out of the inj that had the blown out o-ring. Do I have to replace the injector now?
Here's the kit on the left. I don't see that piece anywhere?
Old May 6, 2010 | 05:44 PM
cartmanea's Avatar
cartmanea
The kits I bought came with that piece. That is collar between the d-ring and clip in the top of the injector, correct?
Old May 6, 2010 | 06:01 PM
npccpartsman
I don't know what it is but there is some kind of piece between the two pieces in question.
Old May 6, 2010 | 06:29 PM
Mihylo33's Avatar
Mihylo33
Yeah that piece is in between the circlip and the o-ring.
Old May 6, 2010 | 06:31 PM
cheezit's Avatar
cheezit
I hgave had success in just replacing the o-ring with out removing anything else. its a pain in the butt.
what method did you use to get the clip out?
also the metal d ring (the broke part) you need to make sure that you have all the pices of it, if not you need to find it before it passes threw the oil pick up and in to the g-rotor. if it does pass its a very costly amount of damage.
Old May 6, 2010 | 07:44 PM
npccpartsman
Didn't they make the pickup screen smaller on the newer trucks because of problems with things going through the screen into the g-rotor? I know the roller needles in the lifters will absolutely FUBAR a motor when they hit the pump. It's not a pretty site. I know someone that just had it happen on a new hot rod motor. OUCH.
