2002 Explorer 4.6 timing chain guides
Old May 5, 2010 | 01:59 PM
mobilefleet's Avatar
mobilefleet
I might be a mechanic but I've never had the pleasure of working on the 4.6 much in depth. I picked up an 02 Eddie Bauer that runs fine and with good oil pressure but is making the timing chain racket up front. If I can get away with it is it possible on this motor to replace just the guides without messing with timing or needing special tools? Anyone out there that has done this job maybe could offer tips or advice on this motor.
Old May 8, 2010 | 09:30 PM
fordmerc's Avatar
fordmerc
The 4.6 is not known for any timing chain noises like the 4.0 is. Are you sure it is the chains making noise?
Old May 9, 2010 | 08:52 PM
rowekmr's Avatar
rowekmr
I took my 06 Explorer in for what I thought was just an exhaust leak. They also had to replace the timing chain and guides and I never knew I had a problem with that also. It was covered under the ext warrantee though so it wasn't more money. I will check the receipt when I get home to make sure.
88f150*300
Nov 11, 2024 03:51 PM
RRousta
Nov 14, 2020 04:07 PM
bass-n-fire
1997 - 2003 F150
Jul 7, 2016 07:24 PM
scorpion58
1997 - 2003 F150
Jun 13, 2015 10:13 AM
coletrain777
Modular V8 (4.6L, 5.4L)
Oct 24, 2010 07:38 AM
