6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
How do YOU drain the fuel/water seperator???
Old 05-27-2010, 08:57 PM
senix's Avatar
senix
senix is offline
Received 1,425 Likes on 1,018 Posts
Always drain monthly. When I was in the Army driving oil burners, I drained daily.
Old 05-28-2010, 02:35 AM
ChargersFanInCO's Avatar
ChargersFanInCO
ChargersFanInCO is offline
I've drained mine twice in a month...not a drop of water, but it only takes a minute.
Old 05-28-2010, 10:19 AM
jshumadine's Avatar
jshumadine
jshumadine is offline
Do you pull the lever and let it drain until no more diesel comes out?
Old 05-28-2010, 12:17 PM
ChargersFanInCO
Naw...drain it until you have about 8oz if there isn't any water in it. The water will come out first. If there's no water in it, just dump it back in your tank assuming the container you drained it into is clean. I use a 16oz gatorade bottle.
Old 10-11-2011, 06:24 PM
politoons's Avatar
politoons
politoons is offline
thanks for your info during your discussion. I am traveling and in tennessee. my drain the separator light came on as I was driving to my temp. home just 15 minutes ago. After logging on and seeing your experiences and advise, went out into a pouring rain, slid under the drivers side and after a minute or two spotted the little yellow handle that moves horizontally from back to front ontop of the separator. got about a quart of green fuel and bubbles out of it until it was a thread width and then shut the valve. I have changed no filters yet as All my tools except an emergency minimum are in Az. I will be changing them next when I figure out where they are and what tools are required.
Old 10-11-2011, 06:30 PM
politoons's Avatar
politoons
what about changing out disc pads on a f-450 4 wheel drive?
Old 10-11-2011, 08:09 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
Don't know about the 450 but I would think they are not much different from the 350 or any other disc brakes. Remove the bolts holding the calipers on, lift the calipers off the disc, pull out the old pads, remove the top off the brake fluid resivor, push the calipers apart with a c clamp, install new pads, don't forget the anti/squeek grease, put the calipers back on and rebolt. Drive for a while making a number of good firm stops. That should do it. But, if I'm wrong I'm sure somebody will tell us here in a few hours.
Tractionless
16
07-14-2020 05:23 AM
smithm31
20
05-03-2016 11:06 PM
dorymill
19
01-15-2012 08:33 PM
Jamie.b
05-31-2011 10:10 AM
resler
11-16-2008 07:00 PM
Quick Reply: How do YOU drain the fuel/water seperator???
