6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Water seperator light
Old May 11, 2011 | 07:42 AM
Jamie.b's Avatar
Jamie.b
The water seperator light came on so I drained it and it did not stop after about ten minutes (about 2 gallons). I turned it off and drained again the next morning for about 3 minutes then it stopped. Later that day it came back on so I drained a little and it appeared to be just fuel. I took it to the dealer and they said I got bad fuel and they cleaned and reset everything. On my way home it comes back on. Anybody have any suggestions?
Old May 11, 2011 | 07:47 AM
senix's Avatar
senix
could be a possible bad sensor.
When you said they cleaned everything..did they replace the fuel filters?
What about taking the cover off of the fuel water separator and seeing if it is all gunked up?
Keep your reciept from the fillup place as you may end up having a claim if you can get it to stop throwing water.
Also try a fuel conditioner too.
Old May 11, 2011 | 08:55 AM
Jamie.b's Avatar
Jamie.b
They said it was slightly gunked up. The fuel filters have about 300 miles on them. I think you are on the right track with the sensor. I am going to run an entire tank of new fuel before I change it.
Old May 11, 2011 | 09:12 AM
Texas450's Avatar
Texas450
There was probaly gunk on the sensor and they cleaned up for you...I have found that happen to me..twice. first time I replaced the sensor second time I pulled the sensor and cleaned it....both times worked
Old May 11, 2011 | 09:13 AM
senix's Avatar
senix
That sensor is easy to remove. I'd suggest doing that.
Old May 11, 2011 | 11:08 AM
joverstr2's Avatar
joverstr2
Mine is doing this also. I'm not sure if I want to tacke it myself yet.
Old May 31, 2011 | 10:10 AM
joverstr2's Avatar
joverstr2
Mine was caked up pretty good. Tech removed all the crap and went ahead and replaced sensor just incase. All good now.
kbuchheit
Jun 25, 2021 11:44 AM
Tanner Jones
Dec 4, 2016 01:24 PM
chi6488
21
Oct 11, 2011 08:09 PM
pdarbs
Oct 28, 2010 03:05 PM
resler
Nov 16, 2008 07:00 PM
