Could it be because it has points?
Old May 4, 2010 | 07:31 PM
JRon's Avatar
JRon
I just got my 74 back from the mecanic, and after a new timing chane, new harmonic balencer, new crank pulley, new front breaks, and compleat tune up, and a pretty good size bill, the truck runs and drives great. But when you hit the key, it still doesn't fire right up. You don't have to pat the gas, but it turns over for a few seconds before it will start. Could this be because of points? I'm wanting to switch to electronic egnition, but thats not top on my list right now. So what do you think the reason could be?
Thanks,
Josh
Old May 4, 2010 | 09:09 PM
73FordF100's Avatar
73FordF100
It could be that or maybe the carburetor needs adjusting. When I start my truck (it has DS I electronic ignition) it takes a couple of seconds to fire up, but my carburetor may need a little adjustment. I think it may be the same way whether or not you have points or electronic ignition.
Old May 4, 2010 | 09:21 PM
Witty73's Avatar
Witty73
I thought 74's were electronic. At least ALL 74's I have ever owned were.
Old May 4, 2010 | 09:30 PM
73FordF100's Avatar
73FordF100
I thought they were all too, but I was proved wrong in a recent thread. I think they said in '74 it was optional .
Old May 4, 2010 | 09:33 PM
Witty73's Avatar
Witty73
Anyways, if you ask me its fuel. Does it Always do it, warm and cold?
Old May 4, 2010 | 09:42 PM
mikeo0o0o0's Avatar
mikeo0o0o0
welcome to the world of carburetors. If you want it to start instantly you'll need to convert to fuel injection.
With everything being fuel injected for the past several decades people have forgotten what its like to drive a car or truck with a carburetor.
And in '74 electronic ignition was an option, made standard in '75
Old May 4, 2010 | 10:13 PM
spudgunman's Avatar
spudgunman
I think a good question was warm or cold, cold if you start up in under a full crank you should advertise for your mechanic.
warm you should be able to tap start in under a full crank turn with a good carb (at least I can
Old May 4, 2010 | 10:20 PM
JRon's Avatar
JRon
Yes in 74 electronic egnition was an option, and became standerd in 75. My 69 i just sold had points of course, and it would fire right up every time wether it sat over night, or you just stopped to get gas. And my last 74 i had, would fire right up the same way, and it had electronic egnition.
Yes it does it all the time, it has a rebuilt carb, maby its just junk.
Josh
Old May 8, 2010 | 09:36 PM
JRon's Avatar
JRon
Just a quick update, I messed with the carb a little bit yesterday, and now she fires right up every time, wether its first thing in the morning, or its ben running a while. Guess that fixed it, but i stil plan on switching to electronic ignition instead of points. Thanks guys.
Josh
Old May 8, 2010 | 10:10 PM
79FordBlake's Avatar
79FordBlake
In use with a stock engine points cause no problems if kept adjusted properly in my opinion. I still have points in my 73 F100, starts with a touch of the key and runs great.
In most of my experiences unless you want to add serious hp or performance gains old Fords run best with stock equipment set to factory specifications.
