so I got a new radio and once I got the superglued(@$#%$) faceplate off and broke loose the rusted clips, I realized that I have no idea what all those wires are for. Anybody have a diagram that will tell me which color does what on a factory original am/fm cassette player?
should be a harness style adapter. It should unplug from the back and you can get a kit from walmart that will adapt anything to your truck. That is what i did. The PO had a POS tape deck in there and so i pulled it out, found the deck i wanted and threw it in with the adapter. The radio section at walmart had all the books/reference stuff i needed on the packaging. Worked well.
Yup. If you still have the OEM harness then get Metra 70-1770 harness. Match your aftermarket wires and simply plug into the factory harness.
I have found that a lot of older trucks, before harnesses were common, if they have an older aftermarket stereo in them the OEM harness will be long gone.
Sounds good...but the old harness had 2 more wires than the new one?, which weren't on that cool sheet you posted. All the speakers work and the CD sounds good soooo, I guess I'll wait till something starts blinking or smoking.
It could be stuff like power ant., dimmer, something else.
