Sway controller recommendations
Old May 3, 2010 | 03:20 PM
mikesmayhem's Avatar
mikesmayhem
I have a 30' bumper pull and I was looking into sway controls to add to my WD hitch. I have the straight bars so I am limited to a add-on friction sway control but the dealer told me not to waste my $. I was looking at one from Camping World for $60 for an off brand or $110 for a Reese. I don't want to have to invest in a whole new dual cam set-up for hundreds of $. Anyone have some sugeestions as to whether or not these cheaper alternatives makes a difference? My truck is a 2001 Ext. cab V10 4X4.
Thanks in advance for any help....
Old May 3, 2010 | 08:49 PM
RV_Tech's Avatar
RV_Tech
Do they help some? In my opinion, sure. The problem is, as you realize, they have no ability to center the trailer. I use a $60.00 model, sometimes. Sometimes I don't run a sway control. I know of no advantage to paying more for the Reese model.
My thoughts,
Steve
Old May 3, 2010 | 08:59 PM
c.f.moore's Avatar
c.f.moore
I have used a friction sway control on a 30'er. It helped. It also helped to have the rear tires of the tow vehicle and the trailer tires aired to max rated pressure. Anything to minimize sideways movement helps.
Good luck
Old May 4, 2010 | 11:10 AM
mikesmayhem
I appreciate the help. I figure for $60 it is worth a try. Even if it helps minimize some of the sway that would be good especially when the wife and her girlfriends are using the camper....
EODguyJake
6.7L Power Stroke Diesel
Nov 10, 2014 08:51 PM
fordquist
Dec 16, 2008 05:48 PM
the4by4freek
All Things Towing
16
Jan 24, 2008 07:48 PM
psmith338
May 4, 2005 08:31 AM
