Too Much Sway
I've been towing with pick ups for 25 years & never had a problem solving a sway issue.....until now.
I have a 2003 F250 FX4 Crew Cab short bed. No lift kit. 305/70R16 Goodyear A/T's. I used to pull a 24' travel trailer with extremely minor sway; added a anti sway bar (the friction type) and stopped the sway completely.
I traded that trailer in on a 31 footer. It has approx. 700# tongue weight and sways BADLY! I Installed the anti-sway bar, but it still swayed BAD! On the suggestion of my local trailer parts store, I installed a Reese load distributing hitch (even though my truck wasn't "squatting" with the load) and a "Dual Cam Sway Control".....It's tremendously better, but it still sways dangerously when I pass a tractor trailer or even if a small car passes me at a high rate of speed. I figured I'd re-install the (friction) anti sway bar plus add another one to the opposite side (even thought the literature with the Reese components says it's not needed). Has anyone else experienced this? Any suggestions?
I had the same problem with my X .....
Hitch "pull type" trailers over 26' need a leveling system. This actually ties the unit togeather as one and adds weight to the front steering of the truck. Most people think or assume a weight distributing hitch is not needed just add springs. If set right you will not ever notice your pulling a trailer. 32' long you should change to a fifth wheel type trailer just for turning radius being one advantage.
A longer truck will be more stable. Duel wheels are the best. Bars for the leveling system come in diff spring rates.
Single rear wheels. Could be the tires making the sway, check air pressures. Pay attention to how your trailer is manufactured and where the weight is located, distributed more over the axle and towards the front along with center of gravity height. I know some RV manufactures have a high center of gravity that causes problems due the type of axles used.
You see many trailers pulled down the highway nose diving or jacked in the air and not setting level when loaded.
Hope this may help in the future.....
Your leveling system builds a bridge from the rear axle to the front axle. someone close to you that knows this system could set this up for you if you wish. Note the Airstream trailers how they are built....center of gravity can make a long day towing.
The Dual Cam is a tremendous improvement over conventional hitches. You also need to:
1) Make sure that tongue weight is at least 12 - 15% of GTW (gross trailer weight).
2) Adjust weight distribution spring bars until you move some of trailer tongue weight to front axle of truck. Use a tape measure on level ground to bottom of wheel arches. You may need to use a public scale to make these adjustments. When all is adjusted, both truck and trailer should be almost level. The truck should squat in rear about 1", and should not rise in the front.
3) Make sure you have "E" load range tires. Do not tow with "D" load range. Read the tire sidewall and inflate to near maximum pressure (esp. rear axle). If "E", I think you can increase to 80 psig. I use 70 psig.
4) Reduce "polar moment of inertia" of trailer (about an imaginary vertical axis through center of trailer between axles). This means to get the mass of trailer closer to the trailer axles. Don't hang a motorcycle on the back, for example. If you add weight, do it in front of but close to trailer axles. Water in a rearward tank can be really bad as it "sloshes".
5) Consider adding a Hellwig anti-sway bar to rear axle. Should be bigger than stock.
6) Consider adding air bags to rear axle.
7) Consider using a Hensley Arrow. This $3000 addition will absolutely conquer sway and make towing much more relaxed. Depends upon your situation and how much you intend to tow. I have taken ours all over the western U.S. and have come to be a "believer".
8) Ignore people who say you should have a Fifth Wheel. Yes, they are definitely shorter and are inherently stable. For less money (e.g. Hensley), however, you can have a stable towing travel trailer and still have room in the bed of truck for "toys" (bikes, generators, etc.) you may want to take along.
