Hang-On AC
Old May 3, 2010 | 03:14 PM
pit_of_pity's Avatar
pit_of_pity
Hang-On AC
1972 Ford F100 2WD 390 FE w. PS
This is my current belt set up:
  • 1st crank sheave: crank+fan+alternator
  • 2nd crank sheave: crank+fan+alternator (I installed a two sheave alternator pulley realizing that 2nd crank sheave can only be used for it)
  • 3rd crank sheave: crank+P/S
My hang-on AC has two sheaves (first from the engine lines up with 3rd crank sheave and second should line up with 4th crank sheave which does not exist) At this point everything is leading towards my crank needing to have 4 sheaves, since I doubt that P/S and AC can share one belt. Ford Parts Manual mentions D2TZ-6A312-A crank pulley for '72 w. hang on A/C. I cannot find any info on this D2TZ-6A312-A. Did people who added a hang-on AC system had to completely replace their crank pulley for a 4 sheave crank pulley? Or is there a single sheave attachment pulley that was supposed to be attached to the original crank pulley?
Old May 3, 2010 | 03:35 PM
Danger_Dave's Avatar
Danger_Dave
i had bought a factory unit from ebay and installed it. i had a similar problem i was faced with. what i ended up doing was go to vatozone and they punched in all my info and gave me one belt the perfect size to wrap around the a/c and power steering.
Old May 3, 2010 | 03:48 PM
pit_of_pity
Seems like if I shared A/C pulley with P/S pulley, my P/S pulley would not have enough grab. But then again, what do I know.
BTW, where is your idler pulley located? Mine is just between the distributor cap and alternator on the passenger side.
Old May 8, 2010 | 07:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by pit_of_pity
Ford Parts Manual mentions D2TZ-6A312-A crank pulley for '72 w/hang-on A/C.
Parts catalog only lists the part number, nothing else, but...
You might be able to get the specs from the following:
B. F. WHITE MOTOR CO. in Stanton TX has ONE = 800-953-3321.
No other Ford Dealer or obsolete parts vendor has any.
Old Jun 6, 2010 | 12:41 PM
pit_of_pity
Alright I finally figured this out...not sure if this is the right factory set up, but it works. I've gone through all the P.O. pulleys that came with the engine and found an additional "Mapco" pulley which adds onto crank pulley and acts as a 4th sheave. My current set up is: 1st sheave (crank, water, alternator), 2nd sheave (crank, water, alternator), 3rd sheave (crank, power steering), 4th sheave (crank, idler, ac). Not sure what the origin of the Mapco is, but it works.
KIKKUP
Jan 12, 2022 08:22 PM
LipschitzWrath
Jul 21, 2015 02:08 PM
whackit
Sep 23, 2012 04:40 PM
flagator
Dec 7, 2004 04:54 AM
therigwelder
Jun 16, 2001 11:16 AM
