Electrical issue help please
Old Jun 6, 2010 | 09:05 AM
jsalty's Avatar
jsalty
1970 F100 302 2WD SWB AUTO.
On my way home Friday I noticed my volt meter reading between 15 and 16 volts at 2,000 RPM and about 13 at idle (600 RPM). Normally at 2k I would get just below 14 volts and if I had the blower on I would get just 12 volts..
So today I load the bed up with some stuff for my mother-in-laws garage sale, hop in the truck flip the switch turn the key and nothing... Check battery voltage and it is at 0.38 volts (checked three times with two different meters after checking one of the boat batteries). Battery was new in January.. Voltage regulator (thing on front by radiator, battery side) looks original.
Any Ideas what to change besides the battery?
Old Jun 6, 2010 | 10:53 AM
jowilker's Avatar
jowilker
jsalty, charge it up if you have a charger, swap in another charged battery if you don't, drive it to your nearest favorite auto parts house and have them provide a free analysis. I suspect alt. but V. reg is suspect too.
John
Old Jun 6, 2010 | 02:34 PM
jsalty's Avatar
jsalty
John
Battery would not take a charge, store tested it said it was bunk. Had the voltage reg tested the results were conflicted. The test said it was half good. So I am replacing it. Will take the truck to the auto parts store once the new bat is installed for a alt check.
Old Jun 6, 2010 | 05:07 PM
xstrange's Avatar
xstrange
Yeah, from the symptoms you describe, it sounds like the battery was the victim, and the regulator was the cause. The regulator locked on and told the alternator to "give it everything you've got!" The battery overheated, boiling out enough water that the plates shed electrolyte, and finally shorts out in self defense.
So, yes, replace the regulator before putting in the new battery. If you get 13.0-13.8 volts the alternator is probably fine.
In general, if you see over 14 volts, you're killing the battery. You may be able to drive it home, but the battery will see permanent damage.
Old Jun 6, 2010 | 07:49 PM
jsalty's Avatar
jsalty
[QUOTE=xstrange;8972452]Yeah, from the symptoms you describe, it sounds like the battery was the victim, and the regulator was the cause. The regulator locked on and told the alternator to "give it everything you've got!" The battery overheated, boiling out enough water that the plates shed electrolyte, and finally shorts out in self defense.
In general, if you see over 14 volts, you're killing the battery. You may be able to drive it home, but the battery will see permanent damage.[/QUOTE
Thanks for the info. I figured the voltage reg crapped out when I noticed the 14+ volts on the meter.
Will check the alt output to bat when I install battery tomorrow.
Old Jun 6, 2010 | 09:38 PM
akforceten's Avatar
akforceten
howdy my 72 4x4 f-250 had similar problems replaced v reg alt an still low voltage so i converted to a one wire chevy style alt that had internal reg . when i started the truck had to rev it to 2000 rpm to excite the new alt but it solved all problems going on 7 years now . plus i was able to eliminate a bunch of wires an the old v reg i can take some pics if you want
01EX
Sep 26, 2015 05:04 PM
eman588G
Jun 11, 2015 02:06 PM
laka
May 11, 2008 09:52 PM
cw2
Apr 30, 2005 09:06 AM
