up pipe replacement options for OBS
Old May 3, 2010 | 04:34 PM
shoebear's Avatar
shoebear
International quote for bellowed up pipes (1843486C92) -- $1101.00
Old Jul 16, 2014 | 08:30 AM
fordman16j's Avatar
fordman16j
Originally Posted by shoebear
I'm replacing my engine. Got the old one out, and the up pipes are too chewed up at the turbo ends to reuse -- they couldn't form a good seal, so I need to replace.
1. Does anyone know the Ford part numbers for the up pipes? I've looked at the ubiquitous Powerstroke part number list floating around, and it says Up Pipe-see Turbo Exhaust Collector below. But it never actually lists the part numbers.
2. Ford parts may not be available even if I have the part number. Does anyone know of a vendor or exhaust shop that sells an aftermarket version of these?
3. Are there any upgrades I should consider? International makes bellowed ones which eliminate the donut seals and leaks. These are sold by a number of folks with or without ceramic coating. But they only fit the larger inlet Super Duty turbochargers, not the ones we have.
Thanks for any help you can give.
PN F4TZ-6K854-A$97.591Up-pipe (right)PN F6TZ-6K854-A$47.391Up-pipe Donut GasketsPN F4TZ-6K854-C$8.68/each2Up-Pipe Flange Bolts (bottom)PN W300013$2.17/each4Up-Pipe Flange Nuts (bottom)PN W300050$3.88/each4Up-Pipe Flange Bolts (top)PN W301640$3.83/each4Turbo Pedestal O-ring (small)PN F4TZ-6N653-A$2.371Turbo Pedestal O-ring (large)PN F4TZ-6N653-B$2.421Turbo Exhaust Inlet GasketPN F4TZ-6N640-B$6.881Turbo Exhaust Y-Collector (optional)PN F4TZ-6K854-D$118.151
Read more:*http://www.dieselpowermag.com/tech/ford/1106dp_serious_7_3l_power_stroke_upgrades/#ixzz37aAiBlMo
Old Jul 16, 2014 | 09:19 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Bellowed up pipes are the way to go. Riffraff has ther own with some pretty good reviews. http://www.riffraffdiesel.com/riffra...t-94-early-99/
Old Jul 16, 2014 | 11:44 AM
liftnw8z's Avatar
liftnw8z
Originally Posted by MOOSE_MACHINE
Bellowed up pipes are the way to go. Riffraff has ther own with some pretty good reviews. Riffraff Diesel Bellowed Up-pipe Kit 94-Early 99 - Riffraff Diesel Performance
Yes, I have heard good things about these. May be looking into them myself as well. More budget friendly than the International option but good quality.
Old Jul 16, 2014 | 06:04 PM
IDMooseMan's Avatar
IDMooseMan
Bummer. I'm getting a "502 Bad Gateway" error from that link. I guess I'll try later.
big ole ford
Feb 4, 2017 03:37 PM
joursleridi
Sep 27, 2016 08:54 PM
jk349
Aug 20, 2016 06:17 PM
HKusp
Apr 25, 2014 06:40 PM
kmrod
Aug 14, 2013 05:40 AM
