I'm almost in tears!...
Old May 2, 2010 | 04:09 PM
CarMom04's Avatar
CarMom04
I don't know that I can really call myself a Ford "enthusiast." I am starting to regret my purchase of this '02 Expedition, EB. Please help me!
Here is what has happened: About 2000 miles after purchase the service engine light came on and had a P0171 code; brought it back to dealer-they took 2 1/2 days to tell me they couldn't find anything wrong with it. Reset light. A couple hundred miles later it came back on. SEL starts flashing-had new plugs and boots put on. SEL back on-PCV hose wasn't attached. SEL back on again-this time I was told codes were P0125, P0171, AND P0175. Told I need a MAF sensor and thermostat. Okay, did that. And guess what! Yep, the light's back on again.
Seriously, I am ready to cry. I really can't afford to keep dumping money into this thing. Any help would be GREATLY appreciated.
By the way...only getting 12-14 MPG. Is that normal?
Old May 2, 2010 | 06:35 PM
ford12508's Avatar
ford12508
12-14MPG isn't all that bad for the weight of the vehicle and the 2V engine. As for the codes, don't go to that shop anymore, obviously they do not know what they are doing. My suggestion would be to go to a different mechanic, and put in a complaint with Ford Corporate about the issue with the mechanics at that dealer. I don't really understand how a hose just disconnects itself, sounds like they either forgot to put it back on or did so incorrectly. Mention that and the fact that the same code keeps popping back up and the dealer is not fixing the problem correctly.
I went to a mechanic with my parents Expy, the one in my sig, for the first year of my driving, and the same problem kept occurring over and over again. The mechanic kept telling my dad the DPFE went bad in the EGR system. We went though 3 DPFEs before I finally told the mechanic he didn't know what he was doing, and that he should try replacing the hoses. What do you know, the hose was clogged, nothing wrong with any of the DPFEs he replaced. That was a $300 job each time he did it, I managed to get a few free oil changes out of him for it, along with other small stuff.
Old May 2, 2010 | 07:57 PM
CarMom04's Avatar
CarMom04
I've actually been to a different Ford dealer and another shop since the original dealership I bought it from is about 50 miles away. Apparently no one around here knows what they're doing. Or they just like to make stuff up because I'm a girl. Obviously I need to find a good mechanic.
Old May 2, 2010 | 07:58 PM
fordtech08's Avatar
fordtech08
so now that the light is back on what is the code? run to autozone by your house they will give you the code for free
Old May 2, 2010 | 07:59 PM
fordtech08's Avatar
fordtech08
what area are you in?
Old May 2, 2010 | 08:06 PM
ford12508's Avatar
ford12508
Edit- Disregard this, I had some information wrong
Old May 2, 2010 | 08:09 PM
fordtech08's Avatar
fordtech08
171 is lean bank one, 175 is rich bank two
Old May 2, 2010 | 09:22 PM
CarMom04's Avatar
CarMom04
I did go to Advanced Auto Parts to check it. The code we got this time is the P0171 again.
fordtech08, I'm in the Minneapolis area.
Old May 2, 2010 | 09:53 PM
fordtech08's Avatar
fordtech08
good chance that it could be an exhaust leak on the passenger side, hard to say without seeing the truck
Old May 3, 2010 | 07:57 AM
c_hohensee's Avatar
c_hohensee
I am in the Minneapolis area myself so I know a few shops or would be willing to take a look at it for you. What dealers have you used (you can tell me in a pm if you wish). Again it can be hard to say without seeing the vehicle.
Old May 7, 2010 | 09:27 PM
CarMom04's Avatar
CarMom04
I have no problem saying on here that I bought it from Dave Holt Ford in Hudson and have also taken it to Elk River Ford and Elk River Tire & Auto. What shops would you recommend? Somewhere that has competent employees?
Old May 8, 2010 | 08:59 AM
c_hohensee's Avatar
c_hohensee
If you are in the Elk River area I would call HiTechMotorsport. They are on US 10. They primarily do high performance, but they do auto repair as well. They are about the only ones I will let work on my vehicles if I do not have the time to do it myself. Otherwise I have heard good things about Service Garage of Blaine.
Old May 9, 2010 | 02:36 PM
CarMom04's Avatar
CarMom04
Thank you.
jgardner1227
Feb 28, 2016 02:30 PM
50th ann
1997 - 2003 F150
Jun 23, 2008 03:54 AM
watersurgeon
Dec 11, 2007 09:50 PM
johnkirk
Aug 19, 2007 07:56 PM
Nathan_S
1983 - 2012 Ranger & B-Series
Nov 22, 2005 12:29 AM
