Which oil filter BASE fits?
Old May 1, 2010 | 02:11 PM
DemonRace6's Avatar
DemonRace6
Hi!
I am trying to make a filtering system and I want to try to use oil filters, but I cant find the correct base. Is there a site I can cross reference them?
I am using NAPA 1607 filters, does anyone know what base will fit this filter?
Old May 1, 2010 | 09:53 PM
DemonRace6's Avatar
DemonRace6
Hi!
hmm no one has ever needed to find a base for a specific filter?
Bump...
Old May 1, 2010 | 11:21 PM
SpringerPop's Avatar
SpringerPop
Of course, many of us have.
Unfortunately I'm on the road and not at my home office where the majority of the bookmarks are, where I'd have it on the tip on my mouse.
However, the most common is the base for a PH-8A Fram, which is a 3/4" x 16 thread, and will fit a whole host of filters.
Pop
Old May 2, 2010 | 08:32 AM
DemonRace6's Avatar
DemonRace6
Hi!
Thanks Pop,
The filter says thread size 1-16, I assume 1" x 16 thread?
Old May 6, 2010 | 01:20 PM
DemonRace6's Avatar
DemonRace6
Hi!
Pop,
The filter is 1 - 16. Looks like most Doge Cummins use this type, but I can not find a filter base for it, do you, or anyone else, know where I can find a base with 1 - 16 thread stud?
Thank you.
Old May 6, 2010 | 10:24 PM
SpringerPop
Dunno. I've never used that size.
I don't recall a Baldwin base of that size/thread.
Why are you locked into using this filter? Got lots of 'em?
Pop
Old May 8, 2010 | 08:43 AM
DemonRace6's Avatar
DemonRace6
Hi!
Pop
Just because they are large and cheap. I could use filters that would fit the baldwin base that I have, 1 - 14. Just need to find large cheap oil filters that fit it.
Old May 8, 2010 | 08:47 AM
worm5932's Avatar
worm5932
what are you trying to filter?
Old May 8, 2010 | 08:59 AM
DemonRace6's Avatar
DemonRace6
Hi!
Oil and wast vegetable oil
Old May 8, 2010 | 10:17 AM
Fat Diesel's Avatar
Fat Diesel
Pop
Funny, Pop. My 64 Falcon uses the PH8A and so do the CNC mills in the shop I used to work in.
Old May 8, 2010 | 10:24 AM
SpringerPop
As I said, it's a VERY common filter size, and it's characteristics are why I used it both for my external transmission filtration, and my hydraulic (power steering) system.
Now that we know DemonRace's application, I'd say that this size is inappropriate for him to use.
Pop
Old May 8, 2010 | 11:06 AM
SpringerPop
Try a Fram P3376. Thread size 1 -14. It's a FUEL filter for a CAT, and there are many equivalents including the WIX 33384.
Look here for cheap ones:
FilterBarn
Currently, their cheapest available is a Luberfiner at $5.41 each, and they have 99 of 'em. Cheap enough?
Hope that helps.
Pop
Old May 10, 2010 | 02:18 PM
DemonRace6's Avatar
DemonRace6
Hi!
FilterBarn
Hope that helps.
Pop
Wow that is awesome! Those filters are huge! Perfect for my application! Thank you! I will take pictures and let you know how it works out. Thanks!!
Old May 10, 2010 | 06:02 PM
SpringerPop
And they'll fit the base you already have.
Keep us posted on how it works out for you.
Brewing your own, I presume?
Pop
loudfords
Modular V8 (4.6L, 5.4L)
Jun 18, 2017 08:35 PM
036.0stroke
Apr 18, 2017 05:45 PM
M-S-G
22
Aug 15, 2016 10:11 PM
mufflerbearing
29
Feb 18, 2010 10:08 PM
tjbeggs
Aug 31, 2005 05:29 PM
