Sponsored by: Real Truck
Tire pressure...
Old May 1, 2010 | 01:18 PM
CNC's Avatar
CNC
Tire pressure...
I have a 2003 F250, 4x4, with stock replacement tires, P265/75/R16, I believe. The tires say 80 psi, cold. I've always kept them around 65 or 70 psi.
I'm curious to know what others have their pressure at and if there is any advantage/disadvantage in less/more air.
Old May 1, 2010 | 01:20 PM
gearloose1's Avatar
gearloose1
Assuming alignment and balance is all good...
Take a temperature scanner, and measure the tires temperature at the inside, outside and center of the tread after a run of about 30 min (for your normal drive).
Tire pressure should be set so the temperature is close to identical at all 3 locations.
This procedure will get you slightly different pressures on each tire, depending on the load of the tire at that particular location.
It will vary according to load and speed.
So the pressure right for 40mph around town is different from the 80mph highway speed pressure.
But the method is tried and true.
I started at 80, dropped front to 55psi, and rear to 70 for better ride. But then I am carrying 800lbs only.
Old May 1, 2010 | 03:46 PM
QwkTrip's Avatar
QwkTrip
For normal driving I just run at the pressure on the door tag.
Old May 1, 2010 | 04:50 PM
RickF350's Avatar
RickF350
My truck rides best with about 60psi. That is with Edelbrock IAS shocks, though.
Old May 1, 2010 | 05:29 PM
ruschejj's Avatar
ruschejj
65 for me. I bump the rears up to 75 or 80 if I am towing heavy. Sometimes 75 in the front, depends on the load.
I usually get over 50K on a set of tires. 90% highway driving with trailers. Good even wear, rotate every 10K.
Old May 1, 2010 | 06:34 PM
Tom's Avatar
Tom
I keep mine at the 75 PSI my door sticker calls for. Not that I have a choice with TPMS, but I'd probably run them there anyway.
Old May 1, 2010 | 08:25 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I chalk test the rears, and normally run at about 10psi under the sidewall max unloaded. Fronts I leave pumped up, especially with the diesel sitting on top of them.
Old May 1, 2010 | 08:56 PM
droffan's Avatar
droffan
I tow coast to coast and normally run 70 in the rear and 65 front...
Old May 2, 2010 | 09:02 AM
dkf's Avatar
dkf
There is no way I could run the air pressures on my fuel door when I had the stock tires on my truck. The fuel door say 50psi fronts and 80psi rears. If I would run that empty the truck would get no traction and be a real bear to handle.
Your best bet is to setup the rear tires to wear even at you given load. The 285s on my truck have a max of 65 psi and I run about around 44-48 in the rears and 58-60 in the fronts empty. If I don't air down the rears I get uneven wear and poor traction even with yearly rotations. When I'm loaded though the rears get pumped up to 65 and the fronts will get lowered to 50-55. When you load the back of the truck up with a trailer and junk in the bed it can take weight off the fronts and cause touchy steering if the fronts are over inflated. What I'm saying is its really a trial and aerror process that depends on your tires and the weight thats on each axle.
Old May 2, 2010 | 10:44 AM
BigPigDaddy's Avatar
BigPigDaddy
Simple, yet effective.
ddivinia
Dec 26, 2012 07:10 PM
nomorecummins
6.4L Power Stroke Diesel
Sep 17, 2010 01:32 AM
XBAJBUSX
Aug 22, 2010 11:00 AM
rb8484
Apr 1, 2009 10:24 AM
Starratt04
Apr 5, 2003 10:18 AM
