Van Turbo
Old Apr 30, 2010 | 08:02 PM
homesteader's Avatar
homesteader
Van Turbo
Is the 98 van turbo the same turbo that is used to upgrade or is it to old?
Old Apr 30, 2010 | 08:04 PM
Izzy351's Avatar
Izzy351
That's the older style. You need one from a L99 or up.
Old May 1, 2010 | 01:01 AM
homesteader
Hey Joe off the subject but do you know if every thing on 01 engine fit on a 97-98 block? Just got a 4x4 van with a 7.3. Yep that turbo set up on the 97 looks smaller.
Thanks
Old May 1, 2010 | 08:39 AM
rat49f6's Avatar
rat49f6
98 van turbo maybe a e99 van turbo !
Old May 1, 2010 | 08:50 AM
rat49f6's Avatar
rat49f6
never mind read ur other thread and the build date is 7/97 which should be obs style turbo
Old May 1, 2010 | 10:52 AM
homesteader
Are they any good? My plan was to swap motors if it will work. Do you know if my 01 parts will fit the 97 block such as turbo, up pipes,hpop etc?
Thanks
Old May 1, 2010 | 10:56 AM
rat49f6's Avatar
rat49f6
yeah everything will swap over but you need to take everything off the block except heads
Old May 1, 2010 | 12:04 PM
homesteader
What about water pump ? Would I have swap exhaust manifolds?
Old May 1, 2010 | 11:40 PM
rat49f6's Avatar
rat49f6
i believe manifolds have to be swapped because of the turbo and uppipe differance not sure on water pump
