May Chat Thread
Old May 24, 2010 | 12:25 PM
  #61
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Nope, It's a '37 Ford Coupe ...
Awe, So you're bringing your girlfriend gifts huh!
-Enjoy
fh : )_~
Old May 24, 2010 | 12:34 PM
  #62
greyghost85's Avatar
greyghost85
Fes, I think you been huffin' too much of that ethanol
Old May 24, 2010 | 12:40 PM
  #63
Festus Hagen
Methanoholic
Probably ...
-Enjoy
fh : )_~
Old May 27, 2010 | 02:20 PM
  #64
fepowerguy8's Avatar
fepowerguy8
You are supposed to put the starting fluid in the carb, not your mouth, run out of everclear? .
Well the newer the car I buy the worse the problems are so I'm starting over. My first car was a 64 and now I'm building a 61 Ford Falcon tudor. I finisihed the bodywork and hooking everything up yesterday. Did pretty good, only stabbed myself once with the needle nose pliers, not good when you let go of the handle and it's still inbedded in your hand. So tomorrow I'm going to go back through and double check everything and bleed and adjust the brakes and it should be good to go. I haven't had a Falcon daily driver in about 8 years. Hopefully this 2400 pound monster will fly with the boss 144 . I can't wait to push it to the limit at 60mph
Old May 27, 2010 | 02:44 PM
  #65
Festus Hagen
Methanoholic
Don't forget your pillow ... So you can take a nap while waiting for it to get to 60!
[edit] Forgot this, Starting Fluid should be in ones mouth if they use it in their motor! [/edit]
-Enjoy
fh : )_~
Old May 27, 2010 | 02:51 PM
  #66
fepowerguy8
I have some big hills around here so I should be able to get up to 65mph it's like speeding wildly out of control in a Toyota .
I changed the rear end from a 3.55:1 to a 3.10:1, My last one got 26-27mpg with a 144 and 3.50:1 rear end I expect the same with the 3.10:1 it just won't rev quite as much at highway speeds.
Still dissapointed no one wants to buy my 86, maybe I should get more muddin' and burnout pictures, and get pictures of it doing a wheelstand.
I found a 66 F250 someone put a 460 and C6 in, if I can sell both my trucks I can get it. but not likely to happen in a two week period.
Old May 27, 2010 | 03:35 PM
  #67
greyghost85
a FTE guy in Nebraska, just bought a 52 Tudor. Now, thats going back
Old May 27, 2010 | 10:56 PM
  #68
fepowerguy8
52's are pretty nice. I didn't want anything from the early 50's I wanted something that can handle the highway better since I live in the sticks. So I got a falcon ??? I got the car half apart for $400 and spent maybe $500 in parts and had to put it together, and almost everything is brand new in it. And it's going to cost me about $300 to register it, sad. Where else are you gong to get a running driving car with new everything for $1200. Good thing I have extra collector plates, not like I'll get pulled over for speeding or anything. What's funny is I have 4-point racing harness's in the front in a car that can't even go freeway speeds.
Old May 28, 2010 | 09:24 PM
  #69
fepowerguy8
Well I got the Falcon out of the shed finally. Other then a dead brand new battery it started ok. The "professionally" rebuilt carb from NAPA that was included with the car is junk, no matter what I do I can't get it to run right with it. So I found another carb my dad built over 20 years ago and threw that on and it started easier, but had no power, so I changed the power valve. It got better but still seemed like it was not getting enough gas, then I ran out of gas. So now I have to wait for a charity to give me money for gas to see if I got the carb working right now.
With the rear wagon springs and rear wagon brakes it sits nice and high in the back and stops on a dime. And with the 3.10 rear end it turns no where near the rpms it did with the 3.55 gears. So I'm happy with my swap, just need a decent carb and some gas and I'm pretty sure I have a new daily driver.
Old May 29, 2010 | 08:40 AM
  #70
greyghost85
get some fender skirts and, maybe, a continental kit
Old May 29, 2010 | 06:50 PM
  #71
fepowerguy8
Fender skirts are for my more manly cars like my big Mercury's, only manly cars get skirts . And continental kits are just a pain and always in the way.
On another note it looks like I inherited another project. A guy I know has a 69 Galaxie, 73 F100, and a 79 F250 4x4. He only has room and money for one project. So for sure the Galaxie is going to be striped of it's useful parts and junked and the parts sold off. The 79 is all apart and will be stripped of what is left that is salavagable and junked and what parts will work on the 73 will be saved. So the winner is the 73 F100 trailer special, it's going to get a newly rebuilt 390 and newly rebuilt C6 and the rear end redone and I need to fix all the rust on it from the cab forward, I have already replaced the floors and rockers on this truck. The box is toast as is the tailgate, but it's going to be a work truck so everything needs to be pretty except the box which will get damaged anyway. Sad to see old cars get junked. It all comes down to how much time and money are you willing to spend on restoring something, anything can be fixed.
Something else weird that happened was I was going to move my brothers 66 Thunderbird out of the shed to make room for reorganzing and making a bigger mess and it wouldn't fire. Checked a bunch of things and turns out the pertronix unit in the distributer went out, good thing we had another one, threw it in and fired right up. I've had quite a few pertronix setups as well as many people I know, this is the first I've ever seen go out, odd.
Old May 31, 2010 | 10:23 AM
  #72
fepowerguy8
Thanks to all the the people that have fought to protect what little freedoms we still have. Thanks again to all who have served, are serving and will serve.
Old May 31, 2010 | 10:36 AM
  #73
Rogue_Wulff's Avatar
Rogue_Wulff
Quoted for truth!
Old May 31, 2010 | 04:10 PM
  #74
greyghost85
today, has been an odd day. I finally got the old truck running! But after all this time, it is somewhat, anticlimatic. Now, I see the 239 other things she needs
Old May 31, 2010 | 06:03 PM
  #75
Rogue_Wulff
Congrats on making it run. I had faith in ya all along.
I went and drug my other RX7 out of the weeds, dropped a battery in it, and discovered the starter went belly up. Since I still had the chain hooked on it, I gave my son a quick lesson on push starting a stick, and hopped back in the old ford. 20 ft later, I heard a loud racket and knew it was running. After tinkering with it a bit, and driving it around, I parked it in an area I can more easily swap the starter. I have a couple spare starters, which is good. RX7 #3 also needs a starter.......
Yep, I have 3 of them. I bought one, and the other 2 were freebies.
BTW, it's hot here, too......
