truck wont start after tranny swap
Old 05-01-2010, 10:42 PM
LCAM-01XA's Avatar
LCAM-01XA
LCAM-01XA is offline
Well usually when the air box is off you don't get water in the intake, the usual scenario is water dripping on the rear edge of the air box lid and pooling there and only then overflowing towards the center bolt and from there down into the intake plenum. Give it a shot anyways tho, but when you pull the plugs (all of them too) try to rotate the engine with the breaker bar first, then when all the water is out you can hit the starter - yeah it's a pain but you won't bend any rods like that
Old 05-02-2010, 09:37 PM
nwebbe1079's Avatar
nwebbe1079
nwebbe1079 is offline
soooo... I pulled all the gps today, and the one aft on the driver side came out without the tip... awesome, dosnt look broken just the whole tip is missing, it was also the only ac delco plug, the rest were autolites. I geuss the previous owner thought it was too much trouble to reach. anyway I didnt try crankin it after I found that im just gonna have to pull the injector off... might be able to reach it through there ive never tried it on these engines. But I geuss if I cant ill have to take the heads off to reach it huh? If I do snd nothings damaged I geuss id be a good time for a head stud kit and a turbo!!! I tryn not to be too pissed about it but oh man I was at the time.
Old 05-02-2010, 09:57 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
A couple people in here have started their engines and driven their trucks till the glow plug tip blew out.
Lay a rag over the hole before you start the engine, the tip will be like a bullet when it comes out.
Old 05-02-2010, 10:12 PM
nwebbe1079's Avatar
nwebbe1079
out the gp hole? ill give it a try i geuss, worse comes to worse ill have to rebuild the motor or jus go pull another one. If the water in the intake was the problem to begin with. ill firgure it out eventually its just been frusturating seein it parked for a few weeks with barely any time to work on it.
Old 05-02-2010, 11:01 PM
Dave Sponaugle
Most times after the fluid stops entering the cylinders, it will drain through the ring gaps to the oil pan.
That may take some time, but it will drain out.
If the hood to firewall gasket is shot, water may be draining on top of the air cleaner or into the intake every time it rains.
That water will wind up in a cylinder and can hydrolock the engine.
It don't take much fluid in the cylinder to hydrolock the engine.
Old 05-03-2010, 01:22 PM
Marianna2003's Avatar
Marianna2003
Marianna2003 is offline
If the GP didn't give you any resistance when you took it out, there's a good chance that the tip has already been blown out the exhaust. If that's true, you dodged a major bullet. David85 can tell you what might happen if the tip gets caught between the head and piston.
Good luck,
Gene O
Old 05-03-2010, 01:45 PM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
So can I as soon as I get the heads off ... Don't sound good thats for sure!
-Enjoy
fh : )_~
Old 05-03-2010, 03:58 PM
nwebbe1079's Avatar
nwebbe1079
ill probably get to it sunday, gotta do head gaskets on my buddies bronco on saturday...dosnt it suck to have friends who tempt you with beer in exchange for workin on their car?
Old 05-03-2010, 07:32 PM
Dave Sponaugle
In your first post you said you "even put in a new red top".
Are you trying to start on one battery?
Two 850 CCA batteries are needed.
Old 05-04-2010, 06:40 PM
nwebbe1079's Avatar
nwebbe1079
yes i only put in one, however, i did have it cranking with one 550 cca battery and a 450 cca jump box and it started fine, chould I try putting in another battery? (after i verify teres no glow plug tip in there of course)
Old 05-04-2010, 11:01 PM
Festus Hagen
Methanoholic
You won't get the cranking RPM's needed with a single 550cca battery even with a jump box.
These IDI's use an incredible amount of amps for startup.
As Dave stated, you need 2 good 850cca batteries, One could get away with less on a near perfect starting motor, any problems and you'll kill them.
-Enjoy
fh : )_~
Old 05-06-2010, 08:24 PM
nwebbe1079's Avatar
nwebbe1079
ok... before i pull it apart any further ill invest in another battery
marshpoprock
16
03-21-2021 10:39 PM
b.simone1210
1978 - 1996 Big Bronco
06-23-2013 12:13 AM
Wooticus
06-16-2013 11:57 PM
Catfish369
Bronco II
08-24-2010 10:02 AM
jln_Wasabi
Electrical Systems/Wiring
03-03-2004 10:36 PM
Quick Reply: truck wont start after tranny swap
